Post by davefab on Jan 28, 2017 18:43:38 GMT
Cheers rikk , we haven't had a chance to check it with the stock brace yet so can't say for sure. We'll try and get hold of a standard brace and let you know...
Post by atlex on Jan 29, 2017 12:42:04 GMT
I just checked the photo and I'm pretty darned sure it'll fit.
Post by myothercarsa2cv on Jan 29, 2017 20:33:44 GMT
How is the jacking bar coming along? Still keen I'd also be keen on an extended shifter with shorter throw produced to a higher quality than the eBay £30 ones. Especially if it had a bend in it to get it closer to the driver. Either that or just an angled extension. Only one you can get is in the US.
Post by davefab on Jan 30, 2017 10:33:58 GMT
The jacking bar is still happening myothercarsa2cv - we weren't happy with the first prototype so we've redesigned it and having a new batch cut now (they're with the laser cutter). Pictures will be up soon
rikk
Post by rikk on Jan 30, 2017 15:32:13 GMT
Cheers rikk , we haven't had a chance to check it with the stock brace yet so can't say for sure. We'll try and get hold of a standard brace and let you know... I'm not close enough to pop over otherwise I would. Happy to take a bunch of measurements though if that would help. Agree with atlex, it does look like it would fit to me.
Post by myothercarsa2cv on Jan 30, 2017 16:26:35 GMT
The jacking bar is still happening myothercarsa2cv - we weren't happy with the first prototype so we've redesigned it and having a new batch cut now (they're with the laser cutter). Pictures will be up soon I'm excited
Post by muckingfuppet on Jan 31, 2017 23:02:09 GMT
Could do with a UK supplier of a coolant reroute setup. The spacer could be one for you to tweak and offer up Dave?
Post by atlex on Feb 10, 2017 12:25:10 GMT
Could do with a UK supplier of a coolant reroute setup. The spacer could be one for you to tweak and offer up Dave? a coolant reroute setup that comes with everything needed, well measured, etc, would be a great option !
Post by BikeTuna on Feb 10, 2017 15:17:16 GMT
Heres an idea for you...
Blanking plates for when you remove your sun visors, bolt into the original screw holes - nothing new there, but what if they also had adjustable maplights in them?
If you make these I wasn't a pair for free for suggesting such an awesome idea!
While you are there, can I also have a side mount number plate bracket that has a built in timing strut? ta...
Post by atlex on Feb 10, 2017 17:15:30 GMT
Jass already does the blanking-plates-with-lights. an adjustable light tho, that is a new idea.
Post by BikeTuna on Feb 11, 2017 0:37:14 GMT
Exactly... I've sent the jazz ones and they are nice interior lights, but I want proper maplights, ones the passenger can angle without dazzling me while driving.
Im working through a list of things I'll finally get around to buying, when the 3d printer gets to the top this would be one of my first projects.
Post by davefab on Feb 11, 2017 9:56:19 GMT
Exactly... I've sent the jazz ones and they are nice interior lights, but I want proper maplights, ones the passenger can angle without dazzling me while driving. Im working through a list of things I'll finally get around to buying, when the 3d printer gets to the top this would be one of my first projects. A 3D printer has been the top of our list for a while now as well. Ours is now on order and arrives at the beginning of March - can't wait for it to turn up, it's going to make a massive impact to everything we do. From printing actual products like these to really accurate prototypes of our manifold's and other fabricated parts, it's going to get a lot of use! Exciting times 😊
Post by rhyswh on Feb 24, 2017 23:24:30 GMT
I have been drooling over your work on Instagram for about a year and just found out your 5mins away from me! (I'm in Trowbridge)
If you ever need a mk1 1.8 as a guinea pig just let me know 😋
Post by rhyswh on Feb 24, 2017 23:31:29 GMT
Forgot to ask is there a rough price for the cold air intake?
Post by rhyswh on Feb 25, 2017 9:29:28 GMT
Don't worry, seen it on Instagram
