Post by FFS Corders on Jul 18, 2018 17:20:52 GMT
I used bp ultimate at 5fest and people with turbos were shocked I don't have one Make of that what you will
jon
Petrol
Jul 18, 2018 19:20:10 GMT
Post by jon on Jul 18, 2018 19:20:10 GMT
Can't speak for later models but I compiled years of mpg data for my previous Mk.1, both normally aspirated and supercharged, and can confidently say that brand and octane made absolutely bugger all difference to fuel economy. While NA, supermarket 95RON was just as good as premium brand high octane stuff with secret cleaning ingredients, tested over multiple fillups with each. Knowing how the mk1 and mk2/2.5 ECUs work, this doesn't surprise me at all... On an 'agricultural' ECU like wot is in those cars, there's no capability to advance the timing to take advantage of higher octane fuel, only temporarily retard it (on models where a knock sensor is fitted, mk2.5?) if knock is detected. Cars with modern ECUs will actually adapt the timing to the fuel grade so economy and power will change dependant on grade. The only thing that super unleaded will get you on an early '5 is knock resistance, which is probably only relevant if you have manually adjusted the base timing a lot, have an aftermarket ECU running a lot more advance, or forced induction which has been mapped for super...
Petrol
Jul 19, 2018 12:07:22 GMT
via mobile
Post by Rickster on Jul 19, 2018 12:07:22 GMT
As far as I am aware the quality standard of fuel is good enough in the UK that there is no point in using expensive fuel with the standard ECU on a mk1 or 2 unless of course it makes you feel good - like people who convince themselves that Farmers Market produce tastes better!! The timing advance mod proves this - 10 degrees was set to allow for bad quality fuel - the fact that we can advance by about 4 degrees shows that standard fuel is good
Petrol
Jul 23, 2018 16:49:15 GMT
Post by wannabe on Jul 23, 2018 16:49:15 GMT
Soooo... has anyone worked out their figures after adding the magic EcoMax additive stuff yet??
Post by Dweenimus on Jul 23, 2018 17:20:25 GMT
Almost! But I'm not sure including a trackday on the tank counts
Post by dadbif on Jul 23, 2018 23:21:15 GMT
Later this week...,
Post by dadbif on Jul 26, 2018 15:33:54 GMT
The results are in, 28.18mpg, but the previous figure included a bit of motorway cruising
Petrol
Jul 26, 2018 17:20:35 GMT
Post by wannabe on Jul 26, 2018 17:20:35 GMT
Local Tesco got momentum so I brimmed it, 33.19 to the gallon! Not bad, motorways and thrashing about. Additive in, will report back The results are in, 28.18mpg, but the previous figure included a bit of motorway cruising I'm thinking this experiment is going to be hard to carry out with due scientific rigour due to somewhat changeable conditions lol
Petrol
Jul 26, 2018 21:46:12 GMT
via mobile
Post by dadbif on Jul 26, 2018 21:46:12 GMT
I reckon the additive may be useful as a knock inhibitor if you are boosted, but increased mpg? In your dreams
Post by Dweenimus on Aug 5, 2018 10:33:05 GMT
So the last fuel up is with the octane booster. Which included a trackday... Next fuel up should show better results
Petrol
Aug 5, 2018 11:27:09 GMT
Post by wannabe on Aug 5, 2018 11:27:09 GMT
I'm guessing 22.57 was a trackday? lol
Will look forward to the results!
Petrol
Aug 5, 2018 13:41:28 GMT
via mobile
Post by Dweenimus on Aug 5, 2018 13:41:28 GMT
I'm guessing 22.57 was a trackday? lol Will look forward to the results! Ummm I think it was an Autosolo during that fill up! And double driven so probably used a fair bit of fuel!
Petrol
Aug 21, 2018 18:41:05 GMT
via mobile
Post by dadbif on Aug 21, 2018 18:41:05 GMT
23.8 mpg with the magic juice, I need to slow down...
Petrol
Aug 24, 2018 13:26:18 GMT
Post by martiny on Aug 24, 2018 13:26:18 GMT
34.5mpg average for the last four fillups (1200 miles) in my Mk.1 1.8.
Better than usual by 2-3 mpg. Maybe a mix of hot weather, school holidays and commuting a little later to miss the worst of the traffic.
Petrol
Aug 24, 2018 14:16:21 GMT
Post by howardb66 on Aug 24, 2018 14:16:21 GMT
I tried it in my TVR, no increase in MPG & got a nasty oily smell from the exhaust when stationary ππ
