Post by BikeTuna on Nov 17, 2018 17:46:57 GMT
I've seen an 1.6 engine advertised which is apparently from a factory Mazdaspeed car, so features the Mazdaspeed/323gtx pistons and cams.
Is there any real world benifit to me getting this? My car is a turbo, would I see any gains for this engine over a standard 1.6?
Post by dadbif on Nov 17, 2018 21:55:23 GMT
Probably if you were NA, but I doubt it since you’re turbocharged
Post by Vindi (Russell) on Nov 17, 2018 23:40:49 GMT
Depends exactly which engine it was, Mazdaspeed did several versions ... some for FI which could be good, and some for NA which could be bad due to the higher compression
Post by atlex on Nov 17, 2018 23:50:03 GMT
to fill in a bit on Vindi's comment..
if it's a b-spec or heavenly wtf c-spec it'd be worth having... if it's a 323gtx familia gtr jobby, the rods are the thing to get ahold of, they're good for more boost/abuse.
Post by Zed. on Nov 18, 2018 0:57:47 GMT
323gtx were turbocharged and had a B6T engine. these had lower compression ratio than the N/A engine (larger dish in pistons) and stronger conrods... also, iIrc, the exhaust camshaft had less duration so more suitable for turbo (quicker spooling?) Rich.
Post by BikeTuna on Nov 19, 2018 15:07:54 GMT
Looking more at this engine for sale I don't think its the b6t, so I'll leave it as is. Don't want to spend extra money to be where I am or worse.
Cheers all
