Post by V6 on Feb 4, 2020 15:34:49 GMT
Imagine Begbie living next door to you...
"If I come back and that MX5 is still sitting there, I'll Canoeing kick it out!"
Post by dadbif on Mar 4, 2020 21:23:03 GMT
Well, is it running yet?
Post by Zed. on Mar 5, 2020 7:13:11 GMT
I'd have thought there'd have been some kind of pos if there was good news hope its good news Rich.
Post by wannabe on Mar 5, 2020 12:37:44 GMT
I've been helping a friend with court stuff against his manipulative nutter ex (wife), who has pretty much been administering prescription drugs to their child excessively and for no reason, so that's been taking up quite a bit of time. Got to prepare for round two soon as well, which is going to be a PITA but we have no choice.
If it ever stops raining, I will get out there and play with it - it is virtually ready to fire up, so if I can get it started, I'll get the MOT booked. (Annoying that I can't drive it to test run it, other than the short trip to the garage.)
Post by V6 on Mar 13, 2020 18:49:05 GMT
Something like this would be awesome when you want to work on the car... pull it out
Post by wannabe on Apr 3, 2020 15:36:11 GMT
Quick and dumb question...
... drop perhaps a tea/tablespoon of oil into each cylinder, in an attempt to reduce any bore damage from dry pistons while the oil pressure gets up?
Or will that just create a cloud of smoke for little benefit?
Post by Zed. on Apr 3, 2020 16:21:47 GMT
Quick and dumb question... ... drop perhaps a tea/tablespoon of oil into each cylinder, in an attempt to reduce any bore damage from dry pistons while the oil pressure gets up? Or will that just create a cloud of smoke for little benefit? depends, if the oil sits in the middle of the piston then it'll do nothing for the bores & rings bite the bullet, start the engine & enjoy Rich.
Post by wannabe on Apr 3, 2020 16:59:25 GMT
Quick and dumb question... ... drop perhaps a tea/tablespoon of oil into each cylinder, in an attempt to reduce any bore damage from dry pistons while the oil pressure gets up? Or will that just create a cloud of smoke for little benefit? depends, if the oil sits in the middle of the piston then it'll do nothing for the bores & rings I did think that... lol I didn't want to put too much in in an attempt to reach the bore walls and drown it! Will give starting it a go...
Post by V6 on Apr 3, 2020 17:27:51 GMT
Edge of seat moment...
Post by Zed. on Apr 3, 2020 19:13:55 GMT
Will give starting it a go... Rich.
Post by Zed. on Apr 3, 2020 19:20:31 GMT
Rich.
Post by wannabe on Apr 3, 2020 20:17:27 GMT
LOL Stop tempting fate...
Post by dadbif on Apr 3, 2020 21:46:02 GMT
He used to be indecisive, but now he’s not so sure.....
Post by wannabe on Apr 5, 2020 19:07:55 GMT
Coolant refilled and mostly spilt down the front of the car and on the floor Last of the connections checked and reconnected. Tomorrow, if it doesn't slash it down all day, I'll jack it up and drain the oil and refill. PITA not being able to get a trolley jack underneath it and having to use the OEM scissor jack - will definitely be using axle stands so I don't cut myself in half while under it. Have got one of the magnetic sump plugs and silicon(e)? washers to use. Hopefully it won't leak.
Post by dadbif on Apr 6, 2020 6:12:22 GMT
I’m glad you don’t make ventilators...
