Post by wannabe on Apr 10, 2019 15:28:32 GMT
Post by Zed. on Apr 10, 2019 17:34:24 GMT
Plagiarism Lots of good info on MT.net but can be a bit clicky Rich.
Crumpets
Insert witty remark here...
Post by Crumpets on Apr 11, 2019 7:50:19 GMT
Had a read as i'm in process of doing this swap at the mo. I solved my problem with the column by changing to a MK2 intermediate shaft (The half of the column that goes from the rack to the UJ just past the bulkhead)
Some points:
You will need MK2 Subframe, Mk2 Rack, Mk2 Intermediate Shaft, Mk2 hubs. If retaining the PAS, only the hose from the pump - rack fits okay with a little persuasion, the one from the bottom of the res to the rack i'm still trying to find a solution for. I will update when i find one.
Post by wannabe on Apr 11, 2019 9:56:03 GMT
Cool - good luck!
Crumpets
Post by Crumpets on Apr 23, 2019 16:00:24 GMT
UPDATE:
Fitted all up using MK1 line from pump to rack, and a MK2 line from res to rack. Pipes required a little massaging but so far it works okay and holds fluid fine.
Result.
