Post by Rickster on Aug 23, 2019 18:36:00 GMT
Yup, it’s a pig I did mine when I had the engine out but manifold off is the easiest way! I also removed the manifold brace/bracket to make it easier to change the oil filter, just left it off- it’s unnecessary! Have you swapped the sender for the uprated unit which will actually give a bit of needle movement rather than an on/off switch
Post by swordspork on Aug 23, 2019 20:20:11 GMT
I already have the 'proper' pressure sender and gauge as the car is pre '93. I just realised over the period of 18 months or so the reading was behaving differently so that prompted me to test the sender with multimeter - the lack of resistance strongly suggest it's buggered. I've sourced another sender that gives the correct resistance when seeing no pressure.
How many bolts good in the inlet manifold bracket?
Post by Whistler on Aug 23, 2019 20:22:18 GMT
How many bolts good in the inlet manifold bracket? 3 IIRC
Post by swordspork on Aug 24, 2019 17:12:13 GMT
I did it. The father in law came over with a socket that fit the top of the sender and off it came. The new (to me) sender fitted straight in.
Interestingly the old sender did give a resistance reading once disconnected. Although it was quite a bit off what the sources suggest they are meant to read. This goes some way to explaining why I did see some pressure readings but lower than what you might expect. With the new sender the pressure is much more healthy.
