Post by dadbif on Oct 15, 2019 21:37:10 GMT
Modified my megasquirt ignition map
Post by dickie on Oct 19, 2019 18:09:23 GMT
Hi Folks, The 140 MPH speedo is now fitted complete with lockwood face kit. I fitted the TDR Oil pressure sender only to find that the gauge is no different to before it still reads exactly the same, with the same slow response when the engine is switched off.
I am now going to fit the early oil pressure gauge that came with the Speedo.
I am sourcing an early Oil pressure sender as the Track Dog Racing one makes them reads backwards. Switch the ignition on and it reads Max pressure, start the engine and the gauge pressure drops down.
All good fun !!
I will get underneath to sort the tracking and camber caster on Sunday.
Post by zoona on Oct 19, 2019 19:06:38 GMT
gbuk
Post by gbuk on Oct 20, 2019 6:53:30 GMT
Took it out on Thursday and got caught with the roof down in a torrential downpour coming across the top of the Mendips. The wipers could barely cope but I managed to keep the speed up and only got very slightly wet Lesson learnt - it's better to keep going than stop and get drowned
Post by wannabe on Oct 20, 2019 16:59:28 GMT
Took it out on Thursday and got caught with the roof down in a torrential downpour coming across the top of the Mendips. The wipers could barely cope but I managed to keep the speed up and only got very slightly wet Lesson learnt - it's better to keep going than stop and get drowned If you're getting wet, you're not driving fast enough
Post by FFS Corders on Oct 20, 2019 17:26:44 GMT
This happened to me in Italy during my road trip...over 50mph a was fine, but then we hit traffic
Post by dadbif on Oct 20, 2019 19:11:59 GMT
Or on a UK motorway with average Canoeing speed limits!
Post by howardb66 on Oct 30, 2019 18:18:06 GMT
Went straight through the MOT today without any advisories. Yay!!!
Post by dickie on Nov 3, 2019 21:26:44 GMT
I have now fitted the early oil pressure sender and its working and reading real pressure and the gauge responds quickly. Tracking and camber still work in progress.
Post by dickie on Nov 4, 2019 23:09:43 GMT
I am trying to upload video of the dashboard with ITB noises onto U Tube.
Post by dickie on Nov 6, 2019 19:42:19 GMT
And todays project is to make a remote inlet idle air valve manifold to take a Mk2 idle air control valve. This will then feed idle air into my ITB's via a distribution block.
Post by dickie on Nov 6, 2019 19:54:15 GMT
This is the other side, I have got to clean it and glue the spigots in , no point in getting it welded as its only an air valve.
Post by dickie on Nov 17, 2019 17:04:29 GMT
I have now progressed this a bit more. I have had it working on the car but now need to swap one of the spigots for a 90 deg one and make a mounting plate to fit on the right hand inner wing.
Good job I only used JB weld for the spigots a few mins with the hot air gun and out it came.
I have also moved my throttle cable bracket to a lower position so that I can build an airbox for the ITB's ( future Project )
Post by dickie on Nov 23, 2019 16:08:15 GMT
Here is the final fitment of the Mk2 IAT valve showing manifold block above ITBs
Post by wannabe on Nov 23, 2019 18:00:33 GMT
That looks... complex... lol
