Post by dickie on Nov 23, 2019 20:05:55 GMT
Ok a bit of explanation.
GSXR ITBs have four air pipes going to manifold on cam cover for idle control, one port on manifold goes to FPR, one port goes to the ECU barometric sensor, The fat yellow pipe goes to the Mk2 IAC valve, Hopefully once its all sorted I can get control of the IAC valve from the ME221 to sort out the idle speed with lights and AC on. Its all a bit of an experiment to get OEM tickover response. I have also got a DIY coolant re route under the ITBs. As the car has a yellow strut brace I thought I would continue the colour scheme.
Its all classic underbonnet Bullprarrie canoe. ( I thought it would be a good challenge for me )
Post by Zed. on Dec 16, 2019 13:09:59 GMT
recent photo update (yesterday) Rich.
Post by scottydugg on Dec 16, 2019 14:36:56 GMT
Removed some parts and selling some of the stockpiled bits as the finances are not as healthy as they should be, I've fallen fowl of trying to collect too many bits instead of fitting what I have.....that and the rust issue
Post by dadbif on Dec 16, 2019 16:53:41 GMT
When I fitted the to my Westfield that had Jenvey TB’s I only had a single take off from one inlet which went to the barometric sensor on the MS. Tickled the throttle for the first minute or so and then it idled perfectly. It had a TPS as well. Your setup looks incredibly complicated, but life would be boring if we were all the same.
Post by martiny on Dec 16, 2019 17:08:24 GMT
Found the remainder of the sheet of 6mm square galvanised wire mesh I bought 20 years ago to make a discreet high-flow grille before fitting a new front air guide to my first Mk.1 and used it to make another for the new front air guide for my current Mk.1.
Post by dickie on Dec 16, 2019 21:02:37 GMT
Hi Zed, How long before the floor paint sticks to the tyres ? How did you find all that floor space ?
Post by Zed. on Dec 16, 2019 22:13:15 GMT
Hi Zed, How long before the floor paint sticks to the tyres ? How did you find all that floor space ? the paint lifted almost instantly I gave it about 3 weeks to dry them parked a van & car in the unit, moved them a few days later & there was patches missing think it was a combination of cold weather (January) and bad luck floor space is a local council owned industrial unit, was intending to open back up fettlin but the location / neighbours mean it's not good for my clientele I'm looking for diferent location but not much hope..... Rich.
Post by wannabe on Dec 17, 2019 15:25:49 GMT
Today I got dressed in my messing-about-with-cars gear, went on the internet quickly, then looked out the window to see it raining. Again.
Sigh.
Still, looking mild and dry tomorrow...
Post by martiny on Dec 17, 2019 23:41:51 GMT
Found the remainder of the sheet of 6mm square galvanised wire mesh I bought 20 years ago to make a discreet high-flow grille before fitting a new front air guide to my first Mk.1 and used it to make another for the new front air guide for my current Mk.1. It's very therapeutic. Pair of wire snips and a bit of origami. Old one quickly faded to a dark grey which made it virtually invisible deep in the car's mouth. Worked a treat too. Caught some dents over the years which would otherwise have been the radiator or chargecooler rad.
Post by wannabe on Dec 18, 2019 10:57:08 GMT
Found the remainder of the sheet of 6mm square galvanised wire mesh I bought 20 years ago to make a discreet high-flow grille before fitting a new front air guide to my first Mk.1 and used it to make another for the new front air guide for my current Mk.1. It's very therapeutic. Pair of wire snips and a bit of origami. Old one quickly faded to a dark grey which made it virtually invisible deep in the car's mouth. Worked a treat too. Caught some dents over the years which would otherwise have been the radiator or chargecooler rad. I need me some of that for both mine and the missus' cars!
Post by Zed. on Dec 18, 2019 11:48:14 GMT
It's very therapeutic. Pair of wire snips and a bit of origami. Old one quickly faded to a dark grey which made it virtually invisible deep in the car's mouth. Worked a treat too. Caught some dents over the years which would otherwise have been the radiator or chargecooler rad. I need me some of that for both mine and the missus' cars! WAZZAT? Inspiration? Rich.
Post by JamesMk3 on Jan 1, 2020 16:35:49 GMT
Project rear hub started. Soaked everything in PlusGas yesterday. Freed off all of the nuts connecting the arms etc. to the hub. All came loose fairly easily. Only thing I didn't touch was the main hub nut. Getting the centre hub off the driveshaft isn't going to be fun I think. 13 years of corrosion on the driveshaft splines, and almost certainly no copperslip.
Post by howardb66 on Jan 1, 2020 21:31:26 GMT
Did some work on a friend’s Mk2.5 over 2 long days last weekend- New cobalt back box MeisterR Clubrace shocks fitted Paco Strongarms fitted Coolant reroute Mounted supercharger
Post by Horney on Jan 6, 2020 11:25:46 GMT
Nothing, it's feeling sorry for itself in my lock up for the winter. Got a few little jobs I want to do over winter before the spring though.
Post by wannabe on Jan 6, 2020 18:22:11 GMT
Drove V6's V6. Changed my pants.
