Post by Zed. on Jun 8, 2022 20:47:44 GMT
tight / small radius bends can mean stretched metal & thin wall so fun to weld Rich.
Post by zoona on Jun 8, 2022 21:41:06 GMT
tight / small radius bends can mean stretched metal & thin wall so fun to weld Rich. You mean 'fun to grind after bodge-welding it together'?
Post by Zed. on Jun 9, 2022 15:52:05 GMT
tight / small radius bends can mean stretched metal & thin wall so fun to weld Rich. You mean 'fun to grind after bodge-welding it together'? Same thing innit? Rich.
Post by zoona on Jun 12, 2022 16:03:37 GMT
Not the prettiest exhaust you will ever see... Ready to weld up after tacking. The last few centimeters is going to be hard to get the tip in the right place. fnarr. So i wanted to get everythign else welded up properly so there is not room for movement when i do that. I want to try to reuse the one i have already, so that i can simply swap out the back box if i feel like being an absolute tw at to my neighbours. I have also reused the mounting points of the other one, which means this has to sit at a funny angle. But you can;t see it from behind, so it doesn;t matter.
Post by zoona on Jun 14, 2022 12:06:39 GMT
guess who didn't weld up the difficult to get to bits before welding up the easy bits?
Post by Zed. on Jun 14, 2022 16:11:53 GMT
guess who didn't weld up the difficult to get to bits before welding up the easy bits? what do I win? Rich.
Post by zoona on Jun 14, 2022 16:28:26 GMT
guess who didn't weld up the difficult to get to bits before welding up the easy bits? what do I win? Rich. Some 'expert' tips on welding?...
Post by zoona on Jun 14, 2022 18:27:09 GMT
new exhaust works. Much quieter. Still louder than I woudl like, but going to have to suck it up this time.
There is a bit of a rattle that I need to find, and I think it is becuase it has settled off to the side slightly and the tip is touching the heat shield on the bumper. A bit of fettling should sort that out.
Post by Zed. on Jun 14, 2022 20:12:23 GMT
There is a bit of a rattle that I need to find, and I think it is becuase it has settled off to the side slightly and the tip is touching the heat shield on the bumper. A bit of HEAT should sort that out. edited & corrected, the bumper will melt giving clearance Rich.
Post by zoona on Jun 19, 2022 15:58:16 GMT
Either, the tea is ready or it is time to repalce the turbo coolant lines. photos.app.goo.gl/H9YNiKofjvPHQift8I think it is getting worse as well, because when i pulled into the garage it was wet, and a tiny bit of noise. It then got worse in the 2 mins between that and the video. I think I will stay away form it until it has calmed down...
Post by zoona on Jun 19, 2022 16:53:23 GMT
In my old chassis, I had notched the chassis leg flange, so that the turbo didn't rub on it. For some reason I thought I had more room in this one and didn't need to do it.
Turns out I did. It has been wearing a groove in the compressor housing...
Post by niklas on Jun 19, 2022 17:56:28 GMT
Ouch. Nice built in steam cleaner.
Post by Zed. on Jun 19, 2022 21:28:39 GMT
Ouch. Nice built in steam cleaner. water injection? Rich.
Post by scottydugg on Jun 20, 2022 8:16:28 GMT
Did they have heat shielding on them or is it just an age related issue? At least you caught it whilst it's still in the light misting stage!
Post by zoona on Jun 20, 2022 9:52:07 GMT
Did they have heat shielding on them or is it just an age related issue? At least you caught it whilst it's still in the light misting stage! They are original... So 7ish years old. Not surprising really.
