Post by Bilbo on May 17, 2017 12:32:55 GMT
Good work man, nice to see it being sorted properly!
That spit frame is a great idea too.
Post by zoona on May 19, 2017 14:52:26 GMT
This is a lot harder than it looks... Been at it ages and it is no closer to fitting. Perhaps some cooling slots in the panels may help me on track...
Post by minty on May 19, 2017 16:07:37 GMT
Crikey, you're certainly going at it hammer an tongs Can you do mine next??
Wonder what that shell weighs on its own?
Post by zoona on May 19, 2017 16:53:13 GMT
i would wait until you see what it looks like first!
Post by minty on May 19, 2017 16:58:06 GMT
Post by onepaintedman on May 20, 2017 6:45:23 GMT
Epic effort. Impressive work fella.
Post by zoona on May 20, 2017 12:49:58 GMT
Epic effort. Impressive work fella. I refer to my previous comment...
Post by zoona on May 20, 2017 12:51:17 GMT
Got some more stuff in the post: Just look at these sexy mfers:
Post by zoona on Jun 26, 2017 8:02:20 GMT
I have been a busy boy over the last few weeks... Finished off welding the sills: Couldn't leave that crushed framerail like that. I have some rails to go over the top and they wouldn't fit with it like this. This is underside after frame rail fix, and with the rusty patched cleared and painted with rust converter - but before cleaning it all down. At this point, I built some rails that bolted onto the subframes and had 200mm castors on them. Put them back on the car, lowered it down, took it outside cleaned it with pressure washer, left it outside in the 1000 degree heat to dry, and then rolled it back in and put it back up on the spit. There was still a fair bit of prarrie canoe left on the underside, so i cleaned that all of by hand with degreaser. It was painful. I went round a sealed all the gaps i had dug out to fix the rust and to seam weld the suspension points, with some car body seam sealer Then i did all the rust stuff and cavity wax in the sills,and the coating underneath. Just waiting for a couple of more cans to arrive today as I went a bit mental in some areas. Next job is the body work... i have got one side reasonably smooth (the side that required a very big patch panel) and need to work ont he other one. Then need to decide on a colour. I may just stay with the original (to current shell) black. Or i really lie a flat grey, but that has been done to death. Whatever colour i choose, it is unlikely to be the best job in the world...
Post by zoona on Jun 26, 2017 8:09:25 GMT
and at the same time, i decided i shoudl try some dress making for my daughter: I think i am more proud of this than the car!
Post by Bilbo on Jun 26, 2017 9:26:04 GMT
Amazing effort mate, this is going to be spotless when done. Wouldn't put yourself down about it not being "the best job in the world", it's going to be cleaner and more protected than 99% of the ones out there!
tsp
Post by tsp on Jun 26, 2017 10:28:09 GMT
And 100% better than most of us could achieve
Post by zoona on Jun 28, 2017 21:14:24 GMT
Have decided on a colour. Nardo grey, black hardtop, black a pillars, black wheels. This is the grey:
Post by baconsarnie on Jun 29, 2017 7:28:12 GMT
Can't wait to see this finished, great work
Post by zoona on Jun 29, 2017 18:43:59 GMT
All the dirty underbody stuff is done now. I have welded up the aerial hole and filled all the dents on the two rear quarters. Need to smooth out the filler on the lower side of the sills as well. And clean up the engine bay - lots of overspray form the dinitrol stuff. The good news is that I can wheel out the S2 bumper that has been sitting in my garage loft uloved for some tiem now. It has had a hard life, so first step was to rub it down, find the cracks that have been repaired in the past and dremel them out where they have crakced again. Filled with p40 now and partially sanded down. This is a before shot: Then i swapped the boot lid for the original, and started to rub that down. I painted that previously and did a pretty prarrie canoety job. I think I will need to rub it right back to bare metal and fibreglass to do a decent job. I also have my shorty bumper that I fitted up years ago and adjusted the brackets to make it fit. I had painted that, and actually didn't do too bad a job of it, so just rubbed that over with some scotchbrite pad, went over with some primer, and a bit of a rub down and it will be ready for paint. This is the collection of parts getting ready. Next is the doors and bonnet off the current car, so that will put the car out of action. Also the hardtop that i bought recently is in a bad way. Needs some edges rebuilding, and i am not sure what somebody has done to try to paint it in the past, but the paintwork is himalayan...
