Post by howardb66 on Nov 23, 2016 10:08:13 GMT
I thought this was a joke but it actually works! Got a MK2.5 with slightly 'yellowing' headlights which look a bit rubbish, anyway, a couple of minutes work polishing with toothpaste on the lights & hey presto! Bright & sparkly again. Blimey!!!
Post by AndyMk2 on Nov 23, 2016 14:50:39 GMT
Minty freshness too
Post by Meerkat on Nov 23, 2016 15:03:18 GMT
It does work well! Although I'm told that if you want it to last you need to coat them in clear lacquer afterwards otherwise they go yellow/cloudy again quite quickly
Post by joeytalent on Nov 23, 2016 16:02:36 GMT
Brasso also works, but I wouldn't brush your teeth with it.
Post by ditchfinder on Nov 30, 2016 16:17:16 GMT
I've used toothpaste before, works like a charm. The best results I've had on plastic light covers was from an old, un-branded cutting compound. It took half the time to polish up & didn't leave any of the micro scratches / swirls. Have heard autosol is ok to use but never tried it myself on plastic, only glass to help get the road canoe off. As Meerkat says they will quickly go dull again unless you re-coat them with the anti-UV stuff.
Post by BikeTuna on Nov 30, 2016 16:47:06 GMT
I got one of those Fortron kits that an ex-workplace 'gifted' me as I left, but I haven't put it on yet. It comes with a clear coat to be put on after.
Ive heard the toothpaste does the job but you do need to clearcoat after.
Post by striple on Mar 1, 2017 21:12:56 GMT
If i ask what brand of toothpaste you used, is that a bit sad?!
Post by Rickster on Mar 2, 2017 19:01:34 GMT
If I do my sills with colgate will it stop cavities??
Post by howardb66 on Mar 3, 2017 8:36:05 GMT
If I do my sills with colgate will it stop cavities?? Yeah, you need about 6 tubes per side
Post by r6demon on Jun 26, 2018 8:58:55 GMT
guys, what are you coating the lens's with after polishing to protect them?
Post by BikeTuna on Jun 26, 2018 12:28:46 GMT
Holy thread resurrection, batman! I've since used my Fortron kit. it was reasonable. It took a good while to get the job done and it didn't completely go as clear as new, but they were heavily clouded so I'm pleased with the results. If I had more product then I could have done more. The kit came with a UV sealant which rubs in with a supplied cloth and it seems to be holding out. If you're doing the toothpaste route I'd go for a UV protective lacquer that you can get at any halfrauds, but I would have thought a regular lacquer would work just as well.
Post by r6demon on Jun 27, 2018 7:19:57 GMT
Sorry BT, as a newbie I like to run through the old threads and check that I am not re asking questions! This one didnt have the close out detail, sorry! Ive polished both lens's and coated with Fusso Soft 99 wax for now, I will have a look for a sealant next time im in halfords Thank you for getting back to me though!!
Post by FFS Corders on Jun 28, 2018 9:18:20 GMT
Don't panic about bumping old threads
Maybe when they get to 10 years old...
Post by BikeTuna on Jun 28, 2018 14:42:21 GMT
Better to bump an old thread with loads of info in it than repeating it all and then having 20 pags of almost identical search results next time..
