Post by davefab on Dec 6, 2016 14:15:10 GMT
Hi Guys, We’ve been working away in the background and after lots prototypes we are proud to release the first of our range of products for MX5’s. We’ve updated our online shop with a new mk1 tower brace, brake stopper and radiator cooling panel. Brake Stopper - Dramatically increasing brake pedal feel & response the DaveFab Brake Stopper is a compact OEM plus solution to firewall flex.
• Reduces wasted pedal movement by eliminating firewall flex • Mounting to the factory master cylinder studs our Brake Stopper triangulates to a factory captive nut on the shock tower. • Replacing the OEM proportioning valve bracket we have incorporated the factory mounting points for the valve and the throttle cable clip. • Compact triangulated design offers an elegant solution reducing engine bay clutter • Seamless mild steel tube construction with gloss black powercoat for easy cleaning • Easy bolt on installation with stainless fasteners included • Designed and hand built in the UK Please note fitment of the Brake Stopper is not compatible on ABS cars. Radiator Cooling Panel - Maximise airflow through the radiator for optimal cooling performance with our lightweight aluminium Radiator Cooling Panel.
• Precision laser cut profile for perfect fitment • Easy bolt on installation using existing fasteners • Improves engine bay appearance • Reduces engine temperatures for optimal performance during track and spirited driving • Finished in a stealthy satin textured black powdercoat • Laser etched stainless steel plaque shows batch number and manufacture date Front Tower Brace - The lightweight aluminium DaveFab Tower Brace is an elegant bolt on upgrade for your MX5
• Lightweight aerospace grade aluminium allows high strength construction while weighing in at only 1250 grams. • Using state of the art laser tube profiling the precisely cut triangulating arms pierce the main tube and locate on its inside face, allowing an extremely ridged component even before the parts are welded. • Fixed length design with no pivots reduces flex and increases chassis stiffness • Easy bolt on installation • Finished in a stealthy satin textured black powdercoat • Laser etched stainless steel plaque shows batch number and manufacture date • Designed and hand built in the UK Please note fitment of the brace is not possible with the oem airbox in place. For all mighty5’s users we're offering a 10% discount, check the discount code section for more details. Head over to our shop at www.davefab.com/shop and check them out. Cheers, DaveFab
Post by Horney on Dec 6, 2016 14:25:05 GMT
That brake stopper looks a much better design than any of the others I've seen. Good work.
chef
Post by chef on Dec 6, 2016 15:02:52 GMT
Loving the design and look of the kit, looks really good!
Gonna put some pennies aside for the rad cooling panel, looks awesome plus it has my name on it which is got to add to coordination points, ha.
Post by retrorodster on Dec 6, 2016 16:31:07 GMT
Lovely looking work. Do you have a price for the rear jacking bar shown on your site?
Post by davefab on Dec 6, 2016 16:46:05 GMT
Hi retro,
Thanks for your kind words. These are nearing the end of development and with the Mighty 5's discount they will be £126 (normal retail £140), with free shipping to mainland UK.
As soon as they're done we'll post them up here.
Cheers, DaveFab
Post by Horney on Dec 7, 2016 9:08:56 GMT
Post by davefab on Dec 7, 2016 9:27:53 GMT
Don't mind at all, that's awesome thanks! We've been looking into this DriveTribe thing but must admit haven't cracked it yet... Looks like it could be a really big thing and it's cool to see you're in on it early.
Post by Horney on Dec 7, 2016 9:33:41 GMT
It's an interesting idea. I'm hopeful I can use it to drive a bit of traffic here which should be good for you trader types as well as the wider forum populace. We'll see how it goes.
Post by rustywheels on Dec 7, 2016 9:57:55 GMT
That tower brace looks lovely.
Are you considering one that will fit over the standard air box or does that destroy the rigidity of the brace? If not, this maybe the trigger for me to buy a Jackson CAI...
Post by davefab on Dec 7, 2016 11:30:09 GMT
Hi Rusty, cheers We aren't planning one that will fit with the stardard box sorry so you will need something non standard. It would have compromised the stiffness and the factory snorkel really restricts access to the top of the strut tower. We've developed the tower brace in parallel with our (as yet unreleased) cold air intake that takes air from the scuttle area just below the windscreen. We have some pictures of our latest prototype CAI with the tower brace installed on our website here: davefab.com/portfolio/cold-air-intake/ Cheers, DaveFab
Post by rustywheels on Dec 7, 2016 12:08:39 GMT
That's nice, and I love your website too. I was then distracted by the twin scroll manifold. Whilst turbos (currently) aren't my thing, the engineering in that is amazing. 800 bhp! I'd need a change of underwear!!!!
I'll be saving my pennies for the new year.
Post by minty on Dec 8, 2016 12:06:28 GMT
Hi, does the brake stopper work with OEM front brace fitted?
Post by davefab on Dec 8, 2016 13:44:17 GMT
Hi Minty, Must admit it hasn't been tested with a factory strut brace, but we think it will fit. The furthest forward point of the brake stopper is the captive M6 nut on the strut tower. This is roughly inline with the front edge of the fuse box ('97 mk1). The front of the master cylinder actually extends further forward than the brake stopper does. I've attached a picture where the brake stopper is not installed and circled the captive nut that it uses. Hope that helps.
Post by Horney on Dec 8, 2016 13:47:11 GMT
That'll deffo clear factory braces.
Post by minty on Dec 8, 2016 17:12:57 GMT
Ahh, I see, different design to others ive seen - looks smart. Thanks Dave (and Horney for confirming) Will add to my list that I call 'my list of bits'
