Post by Horney on Jan 17, 2018 19:07:40 GMT
Yeah I was surprised at the 2.0 bit as well.
ITBS on a 6 will sound rather sexual. That will require a lot of video content when done.
Post by nibnob21 on Jan 17, 2018 21:15:28 GMT
What's the ECU option? Friend of mine has recently imported a 280z from the States so it'd be interesting to hear what aftermarket management options there are.
Post by joeytalent on Jan 17, 2018 21:41:15 GMT
What's the ECU option? Friend of mine has recently imported a 280z from the States so it'd be interesting to hear what aftermarket management options there are. I'll be getting this kit: zcardepot.com/fuel-injection-retrofit-kit-fast-efi-280z-280zx.htmlFor ITBs, you just need some way of eliminating the AFM, which this will allow me to do as it calculates fuel based on MAP and TPS. I won't be touching the ignition system at all. I'm sure you can buy all the parts in this kit separately and piece it together to work with any ECU, but if I can get it all from one place who will also provide some level of support (plus I've ordered from them before and they've always been great) then I'll take that route. Plus this has the added benefit of using GM sensors, which you can get at any of the motor factors here. If you want to go full management (i.e. control the ignition of the engine with an ECU as well), then your choices are the standard offerings - Megasquirt, Holley, AEM etc. Each one has it's pros and cons, and different levels of support for the L28 out of the box. My experience with my MX5 was that it was fairly painless, as there are tons of guides for Megasquirt and the required modifications, but I'm not smart enough to figure all this stuff out from scratch. Here's the only other company I know of in the US that does ECUs: datsunspirit.com/shop/electromotive-tec-engine-management-systems-for-6cyl/datsunspirit.com/shop/megasquirt-ms3-pro-with-8-wiring-harness/You're safely north of $2000 once you're looking for a full management solution that's plug and play. Get some pictures of your friend's car up on here!
Post by joeytalent on Jan 24, 2018 23:28:15 GMT
The wrong adapter plate arrived, new one should be here soon. The seat is so comfortable, can't wait to get it into the car. Got the universal sliders fitted, glad I went with the Cobra ones - everything lined up nicely, and they came with hardware. Fingers crossed it all fits in the car now...
Post by melx5 on Jan 26, 2018 6:18:23 GMT
The wrong adapter plate arrived, new one should be here soon. The seat is so comfortable, can't wait to get it into the car. Got the universal sliders fitted, glad I went with the Cobra ones - everything lined up nicely, and they came with hardware. Fingers crossed it all fits in the car now... Just ordered a set of these with harness holes, wasn't sure about the cord centre so went for all vinyl. Still waiting for mr postman.
Post by joeytalent on Jan 26, 2018 14:01:19 GMT
Just ordered a set of these with harness holes, wasn't sure about the cord centre so went for all vinyl. Still waiting for mr postman. Nice! I always wanted them in the MX5, but l never bit the bullet. I was very impressed with the build quality and finish - it's a shame you can't get all the options available in the UK in the US. The adapter plate is scheduled to arrive Monday, so I'm hoping to get it in the car Wednesday night, schedule permitting. We're deep into broomball season now, my evenings are quickly taken up with shuffling around on ice chasing a ball with a stick.
Post by joeytalent on Jan 30, 2018 14:11:35 GMT
Grrr. The correct adapter plate arrived, but the holes for the rails are out by 1/8". I contacted the manufacturer, and they confirmed that their design actually has an issue and I'll have to modify the rail. Not the end of the world, but an annoyance.
I'm going to try the adapter plate in the car tonight at least to make sure one part fits.
Post by joeytalent on Jan 30, 2018 21:18:20 GMT
Some classic Minnesotan lunchtime entertainment at work:
Post by joeytalent on Feb 5, 2018 23:57:31 GMT
280Z Winter UpdateWinter is definitely here in Minnesota. We've been hitting under -30°C on a regular basis, and as the car is stored in some unheated storage, progress has been slow. I've been slowly picking up parts from sales and stuff to fit when it gets a bit warmer. That hasn't stopped me visiting the car and starting it up every couple of weeks to make sure everything is still good. Sure, it's a little dusty, but it's been surviving winter just fine. It's actually fired up first time every visit. First up with the purchases - I got a replacement dashboard from Facebook for a steal, with the eventual plan of tidying up all the cracks and refinishing it. Next up, I finally fixed the crooked steering wheel. I managed to do the hub up so tight that I had to use a hub puller, which involved pulling off a bit more interior than expected. And fixed: Also, I finally took stock of some of the parts that came with the car: I've never been happy with the driver's seat in the car, as it has a metal bar right at the base of my spine, which makes long journeys less than pleasant. I've always had a thing for fixed bucket seats, and wanted something period correct that I could fit without modifying the rails in the car. Enter Planted Technology: They make brackets that bolt into the original locations in a car, and then provide mounting points for aftermarket rails. Initially, they sent me the wrong bracket, but quickly resolved their mistake. I test fitted the bracket in the car, and it lines up perfectly with the bolt holes from the original seats. No pictures of that, as it was freezing and I couldn't feel my fingers. Next up, we'll need a seat. I ordered a Cobra Classic RS, made in the UK, along with some universal sliders. I'm 99% sure this will fit in the car - I might lose a little leg room, but I'm not tall enough for that to be a concern. The build quality of the seat is excellent, and it is very comfortable. For the price, and limited room available in the cockpit, I think this is a perfect seat for the 280Z. However, I ran into a problem when it came to fitting the Planted Technology seat bracket - the holes are about 1/8" off lining up with the Cobra rails. I contacted Planted Technology with the photos, and they discovered that they have an error in their design for these particular adapters. It's not a big deal for me, as I can just drill the hole out in the rail to fit. Next time, hopefully I'll be putting the seats in the car!
Post by scottydugg on Feb 6, 2018 8:05:03 GMT
Seats, good! Mounts, good! Pile of parts, good! But your's seems to be a lot more organised than mine Glad to see some more progress on this, a cracked dash is something I've never had to deal with before. What's the plans for it? Don't know if you'll watch them, but eh "Mighty Car Mods" guys on Youtube just picked one of these up, worth a watch.
Post by joeytalent on Feb 6, 2018 13:28:51 GMT
Seats, good! Mounts, good! Pile of parts, good! But your's seems to be a lot more organised than mine Glad to see some more progress on this, a cracked dash is something I've never had to deal with before. What's the plans for it? Don't know if you'll watch them, but eh "Mighty Car Mods" guys on Youtube just picked one of these up, worth a watch. Heh, it isn't that organised. It just has the illusion of organisation. The cracked dash is going to be interesting. I believe you can get flexible filler that is for filling foam interior parts, just like this, but the foam is so old and hard that I might get away with expanding foam and regular filler. Then it will be repainting it with a textured paint - truck bed liner is a popular choice. First up though, it needs to be stripped down and cleaned... which I can't do until it gets warmer. Aye, I saw the MCM video, interested to see what they do with it.
Post by scottydugg on Feb 6, 2018 13:48:13 GMT
Impressive what a set of shelves can do, I'm at the stage I need an inventory.
Dash sounds a good project to get stuck into, here's hoping it heats up soon!
Post by joeytalent on Feb 15, 2018 14:59:23 GMT
I bit the bullet and ordered the ITBs from Japan. Now I have a question - does anyone have any idea which injectors might fit? Someone mentioned they look like "standard Nippon Denso top feed injectors" - which sadly, means very little to me. If anyone can point me towards a car make / model that might have something suitable, I would be super appreciative!
Post by atlex on Feb 15, 2018 15:12:48 GMT
AWESOME!!!1111 Denso are the OEM for most japanese cars. MX5s have them :-) Order some RX8 yellows cleaned and flowed ? they're denso too.
Post by atlex on Feb 15, 2018 15:15:09 GMT
Top feed injectors - rx8s yellows, which are also top feed, look like these:
