Post by suggs84 on Feb 16, 2021 10:59:52 GMT
How did you find fitting the freaky parts rings Scott, do they literally just slide over the top? The smaller dials look obvious but the speedo and revs obviously have a metal look surround already from the factory of course - really fancy some of these for the relatively low cost but i'm nervous about cracking open the dials so if it was a pain in the rear, i'll leave it lol!
Post by scottydugg on Feb 16, 2021 11:56:56 GMT
How did you find fitting the freaky parts rings Scott, do they literally just slide over the top? The smaller dials look obvious but the speedo and revs obviously have a metal look surround already from the factory of course - really fancy some of these for the relatively low cost but i'm nervous about cracking open the dials so if it was a pain in the rear, i'll leave it lol! The existing rings are just glued on, they literally just pull off, the new rings just slide in and need glued in place. I used some Gorilla Glue contact adhesive. I'd buy a couple spare cowls, you might manage first try or you might crack a few, but they aren't that much to pick up I don't think. Something you could do prior to ordering the rings. The only thing is the plastic cover is sometimes quite scratched depending what car it comes out of, I've an acrylic plastic polish I can send you a link to if you need it. Not installed it yet, but I'll get a few pictures once it's in place.
Post by scottydugg on Feb 18, 2021 10:27:55 GMT
Gearbox is now back in it's rightful place: breaker bar across the trans tunnel, some rope and a jack under the middle of the box. Lift it up in stages till it's in the tunnel and won't fall off the jack. Wait for the jack to accidentally roll away during vigorous wiggling of the box, at this stage you're committed, so lift and push or get squished! I don't think the local news would be favourable in their description of local man killed by 5 speed. PSX_20210217_212524 by Scott Reid, on Flickr Getting a scissor jack under the front of the engine to tilt it back seems to have helped, it went in a lot smoother than when we first changed the clutch. Attached the slave cylinder, threw a shifter in it and stuck it in 3rd, turned the crank and..... HwVideoEditor_2021_02_17_212114 by Scott Reid, on Flickr Just quickly on the BOFI clutch, I think I need to re-bleed the clutch, but it feels almost stock in pedal feel. So I'm looking forward to trying it out, glad I went to all the hassle of changing it now. Plan is put the rest of the bell housing bolts in, prop shaft, connect the little wires above the box (I think they can go in any order?), then move onto getting the head back on the engine. The goal is MOT it for April, try keep the momentum going.
Post by suggs84 on Feb 18, 2021 13:54:38 GMT
How did you find fitting the freaky parts rings Scott, do they literally just slide over the top? The smaller dials look obvious but the speedo and revs obviously have a metal look surround already from the factory of course - really fancy some of these for the relatively low cost but i'm nervous about cracking open the dials so if it was a pain in the rear, i'll leave it lol! The existing rings are just glued on, they literally just pull off, the new rings just slide in and need glued in place. I used some Gorilla Glue contact adhesive. I'd buy a couple spare cowls, you might manage first try or you might crack a few, but they aren't that much to pick up I don't think. Something you could do prior to ordering the rings. The only thing is the plastic cover is sometimes quite scratched depending what car it comes out of, I've an acrylic plastic polish I can send you a link to if you need it. Not installed it yet, but I'll get a few pictures once it's in place. Nice, thanks for the info - yes makes sense with the spare surrounds, they are cheap as chips arn't they............. good progress with the car too!
Post by scottydugg on Feb 22, 2021 12:38:44 GMT
Another update (try keep the momentum going). Gearbox bell housing bolts now all fitted along with the starter motor, just need to grease where the slave cylinder meets the clutch fork. Changed out the oil cooler gasket, after buying a 24mm deep socket, apparently this also does the wheel hub nuts. Changed out the fuel filter, it's only been on the car 3 years but I figured I'd swap it over anyway. Even with the fuel system de-pressurised I still got a liberal dosing of the good stuff. Wrote the mileage on it to remind me not to bother next time! PSX_20210222_121217 by Scott Reid, on Flickr Just need to set the PPF, fill the box with oil and refit the gearstick (after I figure out my bronze bush mistake), then we should be done for under the car for a while. Whilst I wait on the gearbox oil I've started dismantling the head, applying assembly lube, once that's done I'll get it built up and put back on the block. Re-assembly always seems to take twice as long as disassembly.
Post by scottydugg on Mar 2, 2021 14:50:51 GMT
So another weekend past, some more progress. Painted the spreader plates, so these are ready to fit with the door bars. Intention is to use a combination of black silicone, Waxoyl and brute force to get them on there watertight. I'll refit the seatbelt tower trim as it won't need a huge amount of trimming. But the foot-well trim might wait till everything's back on the road. Pulled the camshafts out again to assembly lube all the valve train, since it's been sat for a few months. I just need to clean up the block a little then this can go back on. I did re-use my inlet manifold gasket, which was new when I fitted it last year, so I'm hoping that won't cause any issue. All buttoned up ready to go back in. IMG_20210301_213311 by Scott Reid, on Flickr IMG_20210301_213325 by Scott Reid, on Flickr I did have to re-install the exhaust cam twice, missed an unseated valve shim the first time round, that could have been an expensive mistake! All this sunny weather is making me regret all these changes I've tried to make at the same time. In other news, found a local tuner that is happy to tune on my Speeduino ECU, they've done a few already, which is great as they've a good reputation. I'm just unsure whether to get it tuned NA then get it tuned with the Supercharger fitted or muddle along NA on the basemap, fit the supercharger and get it driveable and then get it to them for tuning (They're about a 40 minute drive away). What do folk think? I'm not sure what would need to be done to the basemap to get it driveable with a supercharger in all honesty, may a tuning guru could advise. Anyway, that's where I am for now.
Post by howardb66 on Mar 2, 2021 15:44:15 GMT
Is it possible to drive without the SC drive belt connected? You could then go to the tuner’s on the existing map quite happily.
Post by scottydugg on Mar 2, 2021 16:29:40 GMT
Is it possible to drive without the SC drive belt connected? You could then go to the tuner’s on the existing map quite happily. The way the mount works I'd need to run without power steering, which could be possible I've never tried it, but yeah that could definitely be a good solution. I'll need to give it a shot. The only other thing I could think of is try and borrow the bones of a tune off of someone local, to gingerly run the car down to the tuners. He has a similar setup to me.
Post by timharvey on Mar 2, 2021 17:50:28 GMT
I’m sure when I did this many years ago, I kept the supercharger belt in place but cable tied the recirculating valve open so it didn’t create boost - then drove to the tuners to get it mapped. Was a much more fun journey home
Post by dickie on Mar 2, 2021 17:53:10 GMT
Hi, Its no problem driving without the power steering belt supercharger drive. Our little Mazdas have Power Assisted Steering not power steering. The steering becomes quite heavy at parking speeds but no problem once moving. My old supercharged MX 5 kept throwing it belts, ( MP62 on a four rib belt )with a big intercooler. Remember the engine will have to suck air through the dormant charger without the belt. I had dual throttle bodies so I could just disconnect the charger to intercooler hose and drive like that as the oem throttle position had the tps.
Post by scottydugg on Mar 3, 2021 10:49:10 GMT
I’m sure when I did this many years ago, I kept the supercharger belt in place but cable tied the recirculating valve open so it didn’t create boost - then drove to the tuners to get it mapped. Was a much more fun journey home Perfect thanks Tim, I'll do a bit of research but that sounds a good solution, no re-assembly required at the tuners. Hi, Its no problem driving without the power steering belt supercharger drive. Our little Mazdas have Power Assisted Steering not power steering. The steering becomes quite heavy at parking speeds but no problem once moving. My old supercharged MX 5 kept throwing it belts, ( MP62 on a four rib belt )with a big intercooler. Remember the engine will have to suck air through the dormant charger without the belt. I had dual throttle bodies so I could just disconnect the charger to intercooler hose and drive like that as the oem throttle position had the tps. Thanks Dickie, sounds as though a combination of belt removed and diverter valve wedged open might be the way to go to at least get me there in one piece. I'm not too far away having everything I need to get this fitted out, but I think I might enjoy the car over the summer and then look to fit this all later in the year. Certainly with the BP4W head swap, things have taken a lot longer than I'd hoped for, but then that seems to be the way with modifying/tinkering.
Post by scottydugg on Mar 8, 2021 11:53:39 GMT
Another weekend past and some more work carried out, good to keep chipping away at it, makes you a little more hopeful that it'll actually be a functioning car at some point this year. Anyway, head was completed last post, so first things first, got some help to lift the whole assembly onto the car, this time with some marks to show where the dowels were on each. Went a lot smoother than last time. PSX_20210305_201237 by Scott Reid, on Flickr Just prior to this I gave the piston tops a quick once over with some brake cleaner, shifting the burnt oil deposits. IMG_20210302_193424 by Scott Reid, on Flickr So from here it's pretty much business as usual, refit, re-seal, re-time....until IMG_20210303_212939 by Scott Reid, on Flickr Rear timing plate, that sits behind the cam gears, torqueing bolt to spec: tight, tight, loose. After trying to drill it out, easy outs, shouting at it. I managed to walk it out with a hammer and punch (an hour of my life I'll never get back). IMG_20210304_190751 by Scott Reid, on Flickr Quick run through with a tap and we're back in business. I did discover leaking cam seals tearing it down this time round, so as per Haynes Manual I've tried on the exhaust side, some RTV under the front cap, as well as the usual 6 globs in specified places. See how that goes. All timed up and covers on: PSX_20210305_201333 by Scott Reid, on Flickr Tried setting the timing without locking the cams, not worth it, took less time to lock them in position than it did me faffing trying to get it to work without. Car Passion Channel special: PSX_20210305_201049 by Scott Reid, on Flickr Finally spent some time Sunday fitting the exhaust manifold and exhaust centre section. Always a pain as I've to run thicker gaskets and some paste as they don't align 100% perfectly. IMG_20210307_181519 by Scott Reid, on Flickr Fixed a snapped power steering bullet connector, mocked up passenger door bar for hopefully the last time before fitting in place, cavity waxed the passenger sill. I've a second hand aluminium rad to fit, before I can start the engine, but it's two snapped fan bolts on the bottom edge. I've tried backing them out with grips but no joy, plan is to Dremel slots and try that (maybe with some heat). Bought some left handed drill bits so maybe try them out at some stage also. I think, I've got most of the parts/consumables I need now, it's just a case of throwing enough time at it now.
Post by scottydugg on Mar 10, 2021 14:03:23 GMT
Second hand aluminium rad, was cheap, has more snapped bolts than I thought, totalling 4. The two side brackets are snapped at the top and....when trying to drill a bolt out I drilled a hole in it! I wasn't angry I was just very disappointed Got a guy in work who's going to weld up the hole for me, but I'll only be able to run the two top bolts on the fan. Not ideal, wondering whether I should just scrap it and run the stock rad for now. It does seem to be becoming a bit of a mare to sort out.
Post by Zed. on Mar 10, 2021 14:24:25 GMT
Second hand aluminium rad, was cheap, has more snapped bolts than I thought, totalling 4. how do you snap bolts in an aluminium rad? would have expected the threads to strip in the aluminium heat works to expand the alloy..... Rich.
Post by scottydugg on Mar 10, 2021 14:32:42 GMT
Second hand aluminium rad, was cheap, has more snapped bolts than I thought, totalling 4. how do you snap bolts in an aluminium rad? would have expected the threads to strip in the aluminium heat works to expand the alloy..... Rich. Not 100% sure but all 4 along the bottom came pre loved (snapped). And flush with the mounting boss. Going by the amount of prarrie canoe I flushed out of it, the previous owner wasn't one for upkeep.
