Post by scottydugg on Jun 15, 2020 8:41:48 GMT
Absolutely epic transformation from when you first got it, great work! Thanks Suggs84, it's been a long slog but we're getting there. I've a proper update to come, when I get a chance to finish typing it up.
Post by suggs84 on Jun 15, 2020 10:40:28 GMT
Absolutely epic transformation from when you first got it, great work! Thanks Suggs84, it's been a long slog but we're getting there. I've a proper update to come, when I get a chance to finish typing it up. Nice! Will look forward to reading the update! I know what you mean about typing it all up, took me ages to write mine which is now on here but it's worth it
Post by scottydugg on Jul 13, 2020 8:34:10 GMT
Finally got a look at the original head from the engine that came in the car (which we thought was a Mazdaspeed, but isn't). All the crank journals etc were in good condition, piston rings all seemed ok from a quick glance. BUT.... I know the oil was overfilled for drifting, I'm guessing valve stem seals? Anyway the cranks getting turned into a lamp so it's not all doom and gloom.
Post by Zed. on Jul 13, 2020 10:41:50 GMT
what colour is the inside of the inlet manifold & ports? could be the breather / pcv was throwing oil in & the cylinders were eating it?
Rich.
Post by scottydugg on Jul 13, 2020 10:59:14 GMT
what colour is the inside of the inlet manifold & ports? could be the breather / pcv was throwing oil in & the cylinders were eating it? Rich. Inlet manifold was as black from behind the throttle body, I'm guessing the ports the same, I'll check. How would you know if the rings were toast? Carbon build up below them, near the wrist pin?
Post by scottydugg on Aug 2, 2020 14:49:22 GMT
Who would have thought the Auto-Solo in March would be just before lock-down, lucky to get the car out and try it out in the grand scheme of things. Like most, I've spent time going through projects I've had on the go or planned to do. Started by splitting a spare set of rear lights as a trial, then splitting and fitting LED rings to the side lights, as well as fitting LED bulbs to all external lights (bar the number plate): IMG_20200326_171014 by Scott Reid, on Flickr IMG_20200403_171810 by Scott Reid, on Flickr Painted a chrome rad cowl in stonechip black, replaced ARC intake chamber hoses with red: IMG_20200418_154610 by Scott Reid, on Flickr I'm also selling the ARC Intake chamber if anyone is interested. Fitted a knock of Stebbel horn, as hated the stock option: IMG_20200418_154042 by Scott Reid, on Flickr Located the source of my oil leak, thankfully not the rear crank seal we had already changed, but the front crank seal: IMG_20200413_185831 by Scott Reid, on Flickr Fitted a ducktail to a spare bootlid I had laying about, much prefer it to the R-package spoiler: IMG_20200401_175927 by Scott Reid, on Flickr I'll do a separate post for the BP4W swap as there's quite a lot to fit in.
Post by scottydugg on Aug 2, 2020 15:54:18 GMT
So the BP4W swap, there's a fair bit of info here so I'll try keep it in some sort of order. Just to recap, the head is a 1.8 BP4W from a mk2, it's been stripped down and skimmed 20thou, as well as getting the valves recut as they were too far gone for lapping. IMG_20200527_202318_1 by Scott Reid, on Flickr After machining I stripped it down and applied assembly lube as I wasn't sure when it'd be fitted: IMG_20200605_191240 by Scott Reid, on Flickr Bought a mk2.5 "flattop" inlet manifold, as the mk1 inlet would no longer fit, comparison with a mk2 inlet: IMG_20200430_190250 by Scott Reid, on Flickr As the mk1 doesn't have EGR, I fitted the Jass Performance blanking plates to the back of the manifold. You can also see the set of mk2 injectors, that were sent to Injectortune for cleaning and flow testing. IMG_20200611_220321 by Scott Reid, on Flickr All built up and ready to go on the car: IMG_20200611_215719 by Scott Reid, on Flickr Split the mk1 engine after running through some coolant and oil cleaners: IMG_20200622_182414 by Scott Reid, on Flickr IMG_20200626_183057 by Scott Reid, on Flickr IMG_20200626_183207 by Scott Reid, on Flickr Used the RevLimiter guide for cleaning the pistons, with some Mopar combustion chamber cleaner: IMG_20200716_204705 by Scott Reid, on Flickr IMG_20200721_201407 by Scott Reid, on Flickr Had to invest in a Jass crank bolt removal tool, worked really well and certainly didn't struggle to get it cracked and off: IMG_20200624_192146 by Scott Reid, on Flickr IMG_20200623_194337 by Scott Reid, on Flickr Other than that, it was relatively plain sailing, following the Car Passion Channel timing belt video replaced the: waterpump, front crank seal, cam seals, idler/tensioner pulleys, head gasket, exhaust/inlet gasket, coolant sensors at the back of the head, all engine hoses for red stoney racing items. I also swapped the mk1 starter motor for a mk2 item from Autolink, they were on offer, just to note these only fit with 2 of the 3 bolts and you cannot utilise the mk1 L-shaped bracket either. Where the mk1 unit cranked 3 or 4 times before starting, the mk2 unit cranks 1 or 2. A worthwhile swap. IMG_20200715_201207 by Scott Reid, on Flickr I also swapped in a mk2 throttle body, so it's now got the revised IACV unit, that's much tidier. Slight modification to the throttle cable bracket (moving the cable to the top slot) but you can use a mk1 throttle cable and don't need a later (shorter) cable. On a side note, cleaning your expansion tank? use dry rice, worked a treat. IMG_20200730_191220 by Scott Reid, on Flickr So with new plugs, oil and filters, the car started first time with a bit of help on the throttle. sorted the idle and the timing (14 degrees) ran up to temp and replaced the coolant. Have since been on a couple test drives and have noticed the following: - Oil pressure is now slightly higher than on the original engine - Coolant temps sit slightly lower. - Definitely feels faster as well as smoother on the power. - Certainly pops louder than it used to. Plan would be to get it to the same dyno as before to compare the pre swap to post swap, I've also got a Speeduino ECU to fit at some stage, once I get a wide-band to fit along with it. Anyway, that's quite a lot of information for now, I'll keep testing it until I'm happy to put the under-tray back on. Thanks for reading.
Post by mrwallace on Aug 5, 2020 8:43:49 GMT
Good stuff, looks like the swap went well! Interested to see what the dyno says...
Post by scottydugg on Aug 18, 2020 15:03:10 GMT
Good stuff, looks like the swap went well! Interested to see what the dyno says... As am I, but I think it'll have the Speeduino in it before the next time it goes to a dyno. - In terms of the car, I've had my first proper cold start post swap and it's definitely not running as well as it was cold. Once of the reasons I'm looking into fitting the Speeduino. Also, on start up, I get a nice puff of smoke, it only does it on initial start-up and not when when rev'd. Anyone have any idea what it could be? I'm going to check coolant and oil levels now that i've driven it a couple times.
Post by scottydugg on Aug 26, 2020 11:21:32 GMT
I've decided that a mx5 4-2-1 manifold, decat and mx5 dual back box, is far too loud for me, it's almost as though it bypasses the dual tip and just comes out the shortest route (left tip). So I'm trying to find a single exit that I can run with my silenced decat, I don't want to be "that" neighbour. We're also planning a staycation and I'd like to take the 5 so making it a bit less rowdy has it's benefits. The puff of smoke I was experiencing on startup seems to be lessening the more the cars run. My oil pressure gauge now reads slightly higher than before the swap, but I cleaned the connections, fixed all oil leaks and I'm running the oil on full now, so I hope that's nothing to be concerned about. Coolant also now seems to reach operating temp much faster now, following a complete flush and fresh coolant. Picked up a set of low-pros from ebay, that I hadn't seen before. Bit of digging and I think they are BSP Brainstorm Low Pros (2nd gen), they seem to have been quite popular back in the day before Moss/Jass released their iterations. I'm going to try replace the light units with something a bit more up to date and try them out. They look like this fitted:
Post by scottydugg on Sept 10, 2020 12:10:36 GMT
So I was planning getting the rust fixed on the sills in the next few weeks, but after fitting the silenced decat to the exhaust, I went to routinely check the oil. There was none on the stick...oh dear.
Is it burning oil instead of petrol now, has the rear crank seal completely shat itself, have I completely messed up my engine? who knows.....
I had overfilled the oil after the swap, but drained out what I thought was the correct amount.
As an initial fault find, I've filled the oil to the top of the 0 on the 0.8 mark, I'll assess this after every drive.
Also bought a new PCV and grommet, to replace PCV I fitted that had come with the BP4W head. I'm going to buy a compression tester also.
Help!
Edit: I should add that my oil pressure has been reading higher since the swap.
Post by Zed. on Sept 10, 2020 14:13:26 GMT
drive it like you stole it kill-or-cure attitude time Rich.
Post by scottydugg on Sept 10, 2020 16:20:01 GMT
drive it like you stole it kill-or-cure attitude time Rich. Only thing with this approach is I've spent all this time and money on the BP4W swap, I don't want to wreck the head. Before I'd found this out I had been driving it normally. Will update once I run it a bit more.
Post by scottydugg on Sept 28, 2020 11:18:24 GMT
Spent some time at the weekend carrying out a compression test just to see what's happening in the engine, 185/188/184/190 IMG_20200928_105019 by Scott Reid, on Flickr All seems good, I think my issue is a result of using the supertech valve stem seals, I think I might need to change these to OEM seals, which I'll look into. Also checked the plugs, now that I'm running mk2 injectors/fuel rail on a mk1 ECU: IMG_20200927_172920 by Scott Reid, on Flickr This will be getting swapped out for a Speeduino as soon as the cars back from rust repair, which it goes out for today, I'm hoping nothing terminal is found.
Post by Vindi (Russell) on Oct 22, 2020 6:45:13 GMT
Nice progress, good to see the detail.
