Post by Zed. on Jun 9, 2021 21:41:29 GMT
I ha always assumed I was the old git on this forum.,,. You are old anyway then Dickie, Howard & Vindi?..... horney isn't that young either Rich. (not yet 50 but had a hard life )
Post by dadbif on Jun 10, 2021 6:15:32 GMT
But just think how much knowledge we have accrued…
Post by Zed. on Jun 10, 2021 7:13:27 GMT
if we can remember it Rich.
Post by lowender on Jun 10, 2021 9:17:45 GMT
I ha always assumed I was the old git on this forum.,,. You are old anyway then Dickie, Howard & Vindi?..... horney isn't that young either Rich. (not yet 50 but had a hard life ) I'm 68 with a mental age of 18
Post by dadbif on Jun 10, 2021 14:12:44 GMT
Bloody kids! 74…
Post by atlex on Jun 10, 2021 15:13:36 GMT
Cool photo. Bet you had a good chat!
Post by batou on Jun 10, 2021 17:05:22 GMT
This thread made me feel a lot better about turning 40 this year
Post by dadbif on Jun 10, 2021 21:15:37 GMT
The important thing is that none of our cars ever go fast enough…
Post by Zed. on Jun 10, 2021 21:37:37 GMT
The important thing is that none of our cars ever go fast enough… My car is like wannabee's... in bits for a long time Rich.
Post by howardb66 on Jun 11, 2021 15:59:17 GMT
So, at my most recent sprint, the turbo was experiencing high levels of residual heat which occasionally lead to a small overflow of coolant from the expansion tank if I didn’t do something proactive.
The rad fan wasn’t kicking in as the coolant at the sensor was within the correct range, however, the turbo was F hot as it had just been sat in a queue waiting to go then operated at max boost for a couple of laps, then back to stationary in the paddock with zero airflow. In normal driving it’s not an issue as I always cool down the turbo for the last couple of miles & idle for a few minutes before turning off.
The only thing I could think of was to run the heating full blast as I came off track & then left it on whilst idling for a few minutes. A fan override is needed.
Don’t shoot me down as wiring is one of my many weaknesses……. After mucking about trying to get something working through the (never fitted) Aircon, a friend asked if I used the front fog lights- no, I took them out & use the holes for airfeeds. 💡It’s a switched feed that could be useful… After a quick delve in the inner wing I found the wiring was still there- bingo! So, to cut a long story short, I use this to power the fan override & it works! I have to turn the sidelights on though. But good news, hopefully quick cooling off track 🤞🏻
Post by dadbif on Jun 11, 2021 21:47:15 GMT
Years ago my radiator fan packed up on an Austin Princess, in the summer, in a tunnel, beneath Lyon. I cooked the family, but saved the engine, by running the heating on full…
Post by batou on Jun 12, 2021 18:26:17 GMT
So, at my most recent sprint, the turbo was experiencing high levels of residual heat which occasionally lead to a small overflow of coolant from the expansion tank if I didn’t do something proactive. The rad fan wasn’t kicking in as the coolant at the sensor was within the correct range, however, the turbo was F hot as it had just been sat in a queue waiting to go then operated at max boost for a couple of laps, then back to stationary in the paddock with zero airflow. In normal driving it’s not an issue as I always cool down the turbo for the last couple of miles & idle for a few minutes before turning off. The only thing I could think of was to run the heating full blast as I came off track & then left it on whilst idling for a few minutes. A fan override is needed. Don’t shoot me down as wiring is one of my many weaknesses……. After mucking about trying to get something working through the (never fitted) Aircon, a friend asked if I used the front fog lights- no, I took them out & use the holes for airfeeds. 💡It’s a switched feed that could be useful… After a quick delve in the inner wing I found the wiring was still there- bingo! So, to cut a long story short, I use this to power the fan override & it works! I have to turn the sidelights on though. But good news, hopefully quick cooling off track 🤞🏻 I fixed the aircon fan to the radiator after I did the AC delete for "Additional / Cooling" and it works of the old button, its reassuring to have something like that. Also I'm assuming you have an uprated radiator in the car so might be worth getting a new rad cap with a higher rating (1.1/1.3 bar) might help keep the coolant in the system too.
Post by howardb66 on Jun 22, 2021 11:46:53 GMT
Did a hillclimb last weekend & with a combination of water wetter + with my fan wiring mod, no overheating from the turbo coolant feed 😁😁😁
Post by Zed. on Jun 22, 2021 12:25:24 GMT
Did a hillclimb last weekend & with a combination of water wetter + with my fan wiring mod, no overheating from the turbo coolant feed 😁😁😁 so, is it time to pack dry-ice into the intercooler's fins then for real cooling..... Rich.
Post by dickie on Jun 22, 2021 16:05:35 GMT
Did Someone Mention old Gits !!!!!
I did the Gurston Hillclimb course for my 61st Birthday in the ITB Rs ( Hillclimb Sprint bit )( It should have been my 60th Birthday present but the car was not Registered and Covid put paid to it )
I am now down to the ITB Rs, Dads old 1934 Sports Austin 7 ( Austin used for Hillclimbs too )& a Honda CBR600 for commuting to work, also a 20 foot motor boat packing a 90Hp outboard. ( Boat no good for Hillclimbs )
Cheers Dickie
