Post by Whistler on Aug 4, 2019 8:49:29 GMT
Too much is never enough!
Post by niklas on Aug 4, 2019 16:48:54 GMT
Started to get it back together. The ring gear was easy to transfer over to the new lsd. The bearings however, they where properly stuck. So I had to order new ones and that stopped progress with the diff. Reinforced it when I have it off the car. Also, its hard to find a difference between the FM stage 1 and competition clutch stage 4 pressure plates, color aside.
Post by zoona on Aug 12, 2019 8:28:17 GMT
Is that re-enforcing so you don't slip if you happen to be walking on it? Good thinking...
Post by niklas on Aug 13, 2019 19:45:11 GMT
It's mainly to maximize the surface area. You know, for cooling reasons.
And I heard that the ladies loves diamonds. Err. Men. I mean the men. Cause I drive a 5.
Post by niklas on Dec 14, 2019 16:21:05 GMT
I have done nothing on the car for the last 6 months 🙄
But the family is growing and the garage is slowly becoming a better place to be, getting heated and with better equipment. I'm sure I'll drive the 5 again before 2022, heh.
Post by niklas on Dec 27, 2019 14:49:51 GMT
Not really the car, but I'm slowly making the garage a nicer place to be. It has now got heat since I installed a panasonic heat pump. I also added sockets, 2x400v and 10x230 16A and 2x230 10A is now in. That should lessen the need for extension cords. Optimally I'd paint the walls before this, but I want it warm for 6 months or so first in order to make the concrete totally dry.
Post by niklas on Jan 25, 2020 16:42:33 GMT
I really should paint the walls. Did clean the floor some and installed a vice through the 8mm steel plate that is my table top. It would have been easier if I'd bought the 10.2mm drill for the m12,s, but my taps are good and i need the exercise
Post by zoona on Jan 27, 2020 7:03:54 GMT
looking good. so much nicer to have a decent space to work in isn't it?
Post by niklas on Jan 27, 2020 17:04:14 GMT
Thanks, sure is. Heat and good lighting is so important.
Post by V6 on Jan 27, 2020 20:09:38 GMT
Great work space
Post by niklas on Apr 15, 2020 16:40:10 GMT
Still doing nothing to the car. Got another child, got one of each now. Built a bench, bought a mini lathe/mill. I really hope I can get back to the car soon Also, I already need to install a few more sockets, heh.
Post by zoona on Apr 15, 2020 16:44:53 GMT
Bloody hell. Congratulations... Only seems like 5 minutes ago you had the first one. Does that mean we are all getting old?
Post by niklas on Apr 15, 2020 16:51:26 GMT
1. I think it does.
2. On the other hand, the first one is only 16 months, they are kind of close together. Hopefully it will be awesome for them in a couple of years.
Post by zoona on Apr 15, 2020 18:20:22 GMT
1. I think it does. 2. On the other hand, the first one is only 16 months, they are kind of close together. Hopefully it will be awesome for them in a couple of years. 1. prarrie canoe. 2. Possibly... But hell for the next couple of years, you mental case.
Post by niklas on Apr 15, 2020 18:44:25 GMT
1. I think it does. 2. On the other hand, the first one is only 16 months, they are kind of close together. Hopefully it will be awesome for them in a couple of years. 1. prarrie canoe. 2. Possibly... But hell for the next couple of years, you mental case. Haha, yup, it might well be. Hopefully my SO will let me escape to the garage from time to time
