Post by mazza5 on Feb 15, 2019 21:48:24 GMT
Hi all, looking at getting my 1.8 vvt forged to around the 330bhp mark, do i need to swap my 5 speed for a 6 speeder as I've heard that it is stronger ?
Post by niklas on Feb 16, 2019 16:38:23 GMT
Yes
Post by Whistler on Feb 16, 2019 20:32:54 GMT
Yes
Post by mazza5 on Apr 15, 2019 15:29:50 GMT
Will the 6 speeder cope with this power or should I consider other options ?, also will my 5 speeder prop fit the 6 speeder or are they different ?
Post by thruxton on Apr 15, 2019 16:04:24 GMT
Talk to people who really know what's what...
DaveFab Engineering.
Regards. Rich.
Post by Whistler on Apr 16, 2019 8:33:09 GMT
Will the 6 speeder cope with this power or should I consider other options ?, also will my 5 speeder prop fit the 6 speeder or are they different ? From the guys running big power, it seems more to do with the way the power is delivered than how much is finally made. There are people running 400+ with a 6 speed box - as long as you "roll" into power and don't deliver it in a huge lump you'll be ok. From memory you need a 6 speed prop to match your 6 speed box.
Post by noobie on Apr 16, 2019 8:58:15 GMT
Will the 6 speeder cope with this power or should I consider other options ?, also will my 5 speeder prop fit the 6 speeder or are they different ? From the guys running big power, it seems more to do with the way the power is delivered than how much is finally made. There are people running 400+ with a 6 speed box - as long as you "roll" into power and don't deliver it in a huge lump you'll be ok. From memory you need a 6 speed prop to match your 6 speed box. 6 speed and 5-speed 1.8 props are interchangeable. 1.6 needs a swap.
Post by Zed. on Apr 16, 2019 10:14:06 GMT
6 speed and 5-speed 1.8 props are interchangeable. 1.6 needs a swap.thought the 1.6 NA prop was shorter & maybe diferent drive-flange for the earlier '6"' diff? was under the impression that the gearbox splines (& gearbox length) was common from 1989-2005? Rich.
Post by noobie on Apr 16, 2019 12:49:54 GMT
6 speed and 5-speed 1.8 props are interchangeable. 1.6 needs a swap.thought the 1.6 NA prop was shorter & maybe different drive-flange for the earlier '6"' diff? was under the impression that the gearbox splines (& gearbox length) was common from 1989-2005? Rich. You're right. My bad. So no swap needed unless swapping between 1.6 or 1.8 diffs.
jon
Post by jon on Apr 16, 2019 17:58:24 GMT
From the guys running big power, it seems more to do with the way the power is delivered than how much is finally made. There are people running 400+ with a 6 speed box - as long as you "roll" into power and don't deliver it in a huge lump you'll be ok. It's 4th gear you need to watch out for on the 6 speed box, it's the weakest of all of them due to the construction of the box. It should be ok at 330BHP (flywheel) though, as long as you have reasonable levels of mechanical sympathy..
Post by mazza5 on Apr 16, 2019 18:03:32 GMT
Thanks all for your help, time to hunt for a decent 6 speeder then.
Dependant on the mileage of the 6 speeder I guess it would be prudent anyway to getting the box rebuilt with new seals / bearings etc before installing ?
Is / are there any upgrade parts I should consider putting in to the newly rebuilt box ?, not going down the Quaife route due to cost.
Thanks.
Post by niklas on Apr 16, 2019 21:10:21 GMT
Just put a good working one in. No massive torque mountain, aim for a torque hill. Track duty gets the box hot and kills it faster.
I have one spare, 334whp. Not many track hours with this power, many track hours with 254whp before that.
For street duty, the 6spd will handle more.
Post by Zed. on Apr 17, 2019 22:15:15 GMT
Post by howardb66 on Sept 18, 2020 10:21:02 GMT
Thanks for the link ZED, looks like it’s a straight swap on a 1.8 MK2.5? Ignoring diff ratios etc.
Post by Zed. on Sept 18, 2020 10:38:37 GMT
looks like it’s a straight swap on a 1.8 MK2.5? Ignoring diff ratios etc. hope so got one to go in my '91... with a 4.778:1 diff... and its now a 5 speed (using 2/3/4/5/6 as a close-ratio gearkit with 2.26:1 'first' gear ) Rich.
