Post by noobie on Apr 30, 2019 17:10:11 GMT
Post by martiny on May 3, 2019 16:57:36 GMT
Hmm. I recognise those photos of mangled tabs which have snapped off the friction cones - they're my photos.
I wonder what repair they do to them. Weld the broken friction cone into the case, maybe. Don't know if that's possible.
I asked Tochigi Fuji (via GKN Driveline who own them) if they would supply new friction cones as spare parts and they said no, not possible.
Post by martiny on May 3, 2019 17:01:06 GMT
Actually, their repair "for rally cross" might just mean they weld up the core so it's not a LSD any more, just locked up.
Post by Zed. on May 3, 2019 17:49:54 GMT
£88.00 dont buy much............
Rich.
Post by martiny on May 5, 2019 14:00:29 GMT
£88.00 dont buy much............ Rich. Yeah, if you strip it down, pick out the broken tabs and then set it back up, you can't do much more to make the diff functional again and still only charge £88. Especially when the manufacturer won't sell replacement friction cones. They have to be welding them up, surely.
Post by Zed. on May 5, 2019 15:42:38 GMT
£88.00 dont buy much............ Rich. Yeah, if you strip it down, pick out the broken tabs and then set it back up, you can't do much more to make the diff functional again and still only charge £88. Especially when the manufacturer won't sell replacement friction cones. They have to be welding them up, surely. weld or braze the 'cones into the diff-spool? I'd say that for £88 they don't do any gear mesh etc., maybe just fettling the 'lsd' bit? Rich. Rich.
Post by noobie on May 5, 2019 20:45:50 GMT
Found this video:
Comments mention new cone plates..maybe some laser cut plates + jig for the hydraulic press? Still almost too cheap at 88 for an lsd center rebuild. I doubt that the price includes setup of the pumpkin as well.
Post by Zed. on May 5, 2019 20:54:50 GMT
Found this video: Comments mention new cone plates..maybe some laser cut plates + jig for the hydraulic press? Still almost too cheap at 88 for an lsd center rebuild. I doubt that the price includes setup of the pumpkin as well. if thats the same people that advertise on ebay then £88 dont go far split 3 ways also, are they using a bent torque wrench could be my eyes & the small screen I suppose Rich.
Post by noobie on May 5, 2019 20:56:52 GMT
No idea if those are the same guys or not...should have mentioned that.
Post by martiny on May 6, 2019 13:50:35 GMT
The part they're filing and test fitting in the first 30 seconds (before seeming to press it into place with that big piece of round steel bar) appears to be a new friction cone. They also put one in the other side in the first two seconds and drop the sun gear on top but it's over in a flash so you don't get to see much.
It looks like they have come up with a replacement friction cone part, possible better designed with an inner ring which strengthens the four locating tabs. In which case fair play to them.
<edit> Okay, froze the vid at 1 second, with the caption still on the screen, and there are clearly 2 new taper rings/friction cones/whatever on the bench. One is between the two sun gears and the other to the right of the crown and pinion gears. The design is conventional *except* for a bigger radius where each of the 4 tabs meets the ring, which might be crucial in reducing stress there.
Post by Zed. on May 21, 2019 21:01:48 GMT
as I've recently dismantled a Fugi diff, it would be rude not to add photo's to show the problem. part dismantled, the 'lsd' is still complete but free from the final-drive & housing. the lsd dismantled. the offending 'cones' & their tabs - well, 5 1/2 of 8 were found, some of them had been through the gear-mesh judging by their shape & condition Rich.
Post by martiny on May 22, 2019 10:29:28 GMT
[derail] What final drive ratio is your Fuji diff? Small thing but it's bugging me.
My Fuji had 40 teeth on the crown wheel and 11 on the pinion. 40/11 = 3.636. So it was a 3.6. My torsen has 41 and 10 = 4.1.
That one has 42 teeth on its crown wheel. Doesn't seems to divide to neatly make any of the usually quoted ratios, so I'm curious.
Post by Zed. on May 22, 2019 10:42:58 GMT
[derail] What final drive ratio is your Fuji diff? Small thing but it's bugging me. My Fuji had 40 teeth on the crown wheel and 11 on the pinion. 40/11 = 3.636. So it was a 3.6. My torsen has 41 and 10 = 4.1. That one has 42 teeth on its crown wheel. Doesn't seems to divide to neatly make any of the usually quoted ratios, so I'm curious. erm, I *think* I counted 41 thought it was a 4.1:1 #guess who is off out to the garage for a check Rich. PS. I don't think that is my 4.778:1 Kia Sportage crownwheel & pinion BUT I did have them on the bench to check measurements................
Post by martiny on May 22, 2019 11:21:43 GMT
Actually, I take that back - it looks like 41 after all. Sorry. I tried counting several times but I think I got confused between teeth and gaps on the right hand side of the photo.
