Post by noobie on Jun 11, 2020 7:29:16 GMT
Genuine question - is there actually any need for a baffled sump on a MK1/2, I've not heard of any having oil pressure issues on track? Not sure if the Ma5da cup cars run one? Yes. Sticky tires and good brakes makes you see a dip in pressure when braking hard. What kind of braking G's do you see?
Post by niklas on Jun 11, 2020 10:57:08 GMT
Not sure now really, since I exploded the gearbox on a high speed track during test day. 1g there, but braking like a wuss.
Post by noobie on Jun 11, 2020 11:11:04 GMT
Then its likely already a problem on Ma5da spec cars. Seeing 1.1-1.2G in braking.
khare
Post by khare on Jun 11, 2020 17:30:10 GMT
On a dry track with warmed up PBS pro race pads, R888R's 1.8 brake sizes, brake stopper and RBF600 fluid, I don't know what G's I pull but judging by how violently passengers are ejected forward I'd say a pretty decent amount
Post by niklas on Jun 11, 2020 18:45:01 GMT
Then its likely already a problem on Ma5da spec cars. Seeing 1.1-1.2G in braking. Unless slightly overfilled, I'd say it is.
Post by mrwallace on Jun 12, 2020 9:00:39 GMT
Ok thanks guys, is that only noticed with aftermarket gauges/data logging?
I only have the oem MK1 oil pressure gauge and haven't noticed a dip... but equally I'm not looking at that when braking hard on track!
According to my camera with built in accelerometer I'm seeing about a 1.5g peak under braking.
Post by Zed. on Jun 12, 2020 10:17:26 GMT
Ok thanks guys, is that only noticed with aftermarket gauges/data logging? I only have the oem MK1 oil pressure gauge and haven't noticed a dip... but equally I'm not looking at that when braking hard on track! According to my camera with built in accelerometer I'm seeing about a 1.5g peak under braking. the old saying @if youv've time to look at the gauges then you're not driving fast enough' springs to mind.......... so I'm fitting 'real oil pressure & temperatire gauges in my cars cluster although I'm doing it because I can & for information during 'normal' driving as to baffling, I've seen a fair few engines die (or spin bearings & worse *) thats been cured with sump baffling, I must confess that this was not with a Mazda mx5 engine but my intrest is as I've an engine in bits so as preventative measure..... and because I can Rich. * fords crossflow engines can suffer with 'Alternator failure' - usually as theres a conrod in the alternator
