Post by zoona on May 19, 2021 18:33:35 GMT
In the middle of rebuilding everything. Completely new hard lines made by yours truely, existing braided hoses on the end, existing calipers. Filled the reservoir Got my daughter to do the press and release brake pedal while I open and close the nipple (fnarr). Double checked she is pressing the right pedal and at the right times... Nothing happening, nothing is coming out of the reservoir at all. Checked all nipples to make sure the other three are closed. Initially tried with left rear, but when it did nothing, moved to right front. nada. The pedal feels like it is all hooked up properly, but it has sat for 3 years completely empty. So, questions: - Is there something obvious i have missed? If there is nothing coming out of the reservoir, it points to that rather than problem with the lines doesn't it?
- Can anybody recommend a brake bleeding tool that actually works. Would prefer a hand crank one as i don;t have access to air at the moment. Wanted one anyway, but i figure if that works, then it definitely removes the lines being a problem and points to master cylinder or booster. i think.
Thanks
Post by dadbif on May 19, 2021 21:08:00 GMT
Do you have ABS?
Post by zoona on May 19, 2021 21:11:57 GMT
Post by dadbif on May 20, 2021 7:43:53 GMT
I reckon it’s your master cylinder...
Post by zoona on May 20, 2021 8:28:07 GMT
I reckon it’s your master cylinder... Yeah... I was hoping to not have to take it apart having just filled it up...
Post by zoona on May 27, 2021 10:05:37 GMT
I have now got them mostly bled. I bought a little vacuum pump thing, and once i pulled some fluiod through that, the brakes seem to be working. So it could be that when it was just full of air it wasn't pulling through properly? Anyway, looks ok now. I am able to move the front calipers when i press the brake pedal.
But... when bleeding the rears, i found the bleed nipple to be really loose in the caliper (even when only opened a crack). SO i am getting LOADS of air in the line - iu think this is leaking in through the thread and not coming from the line. Anybody had this issue?
On one side i have put a bit of PTFE tape on the thread (kept well away from the pointy end) and it seems to have sorted it - but I am not sure PTFE tape and brake fluid is a good idea...
What does the collective Mighty5s mega brain think about this situation?
Post by scottydugg on May 27, 2021 10:17:09 GMT
What vacuum pump did you get? When I tried bleeding my non-ABS system, I tried for ages thinking I'd got it spot on, but it'd trapped air somewhere so had to get a garage to get rid of the last bit of air in the system.
Rear bleed nipples weren't overly loose for me, might be worth getting new nips? or worst case scenario your callipers have been fettled with?
Post by zoona on May 27, 2021 10:58:32 GMT
What vacuum pump did you get? When I tried bleeding my non-ABS system, I tried for ages thinking I'd got it spot on, but it'd trapped air somewhere so had to get a garage to get rid of the last bit of air in the system. Rear bleed nipples weren't overly loose for me, might be worth getting new nips? or worst case scenario your callipers have been fettled with? It's just a cheap hand pump one, but it seems to work well. Sorted the fronts out nicely. Calipers are refurb units, but like everything else they have day for 3 years. New nipples might be in order
Post by scottydugg on May 27, 2021 11:05:27 GMT
What vacuum pump did you get? When I tried bleeding my non-ABS system, I tried for ages thinking I'd got it spot on, but it'd trapped air somewhere so had to get a garage to get rid of the last bit of air in the system. Rear bleed nipples weren't overly loose for me, might be worth getting new nips? or worst case scenario your callipers have been fettled with? It's just a cheap hand pump one, but it seems to work well. Sorted the fronts out nicely. Calipers are refurb units, but like everything else they have day for 3 years. New nipples might be in order Only other thing I could think to check would be the connections at the splitter block on the drivers rear, if that was loose you'd get a leak. New nips would be a cheap thing to try first.
Post by zoona on May 27, 2021 12:48:01 GMT
i checked all the connections, and they were not leaking, and when i undid them got fluid coming out - so they all look good. I made the lines up myself (another first time job) so checked them twice... as i can't see fluid coming out, i assume there is no leak of air in either. or is that bullprarrie canoe?
nips would be cheap and easy if i lived in a country where you could just go and buy things like that. people take their cars to the garage to swap to winter wheels here - doing anything yourslef is out of the ordinary. driving me mental.
Plus even if i could find somewhere, I can't drive becuase my eye is Canoeed up. Will order some and try again with the ptfe tape i think.
Post by dadbif on May 27, 2021 17:13:43 GMT
I have never used anything other than a rubber pipe with a 45 degree slit in it and a screw blocking the end. Put the end it in a jar of fluid to stop drawing air back in, shove it on the nipple, crack said nipple then pump the pedal. Just me, no assistants, then lock your nipple and move onto the next wheel. Simple but bloody effective.
Post by zoona on May 27, 2021 17:38:32 GMT
Got my daughter to sit in the passenger seat while I went round all the brakes doing the usual routine. Worked a treat.
We argued the entire time because she didn't want to do it, but it worked
Not buggering about with bloody brake bleeding tools again
It also meant that I discovered the clevis on the brake booster wasn't connected to the pedal correctly. So fixed that too.
Thanks for the replies.
Post by dadbif on May 27, 2021 17:42:50 GMT
Cheap, cheerful, but effective.
Post by warpspeed on Jun 4, 2021 7:15:55 GMT
When the brake pedal is released, the piston(s) in the master cylinder are fully back, and the whole brake system is open to the fluid reservoir. So the least painful way of bleeding is to just fill the fluid reservoir right up to the brim, and apply some positive air pressure to the top of the fluid reservoir via the filler cap. Then you just go around and open up the bleed nipple on each caliper, no pedal pumping required. Only thing you need to be really careful of, is that there is always some fluid remaining in the reservoir. Keep going, and each bleed nipple will splutter and spit as all the air comes out, until you see clear clean fluid emerge, the same colour fluid as you added to the reservoir. Just keep checking the fluid level in the resrvoir and keep topping it up as you go. Eventually all of the fluid will have been replaced and you should have a hard pedal. If not, its likely bubbles trapped in one or more calipers. Belt the crap out of each caliper with a rubber hammer, that should free any trapped bubbles, which you will quickly see with further bleeding. The beauty of this system is you can do it all by yourself without an assistant, and it works. No swearing required or necessary..... I scored myself an extra round screw cap for the brake reservoir, and fitted a compressed air line fitting to that. I run my air compressor for just long enough to see about 10 psi stored pressure in the tank, and then shut off the power. If you don't have an air compressor, you might be able to do something really clever with a spare tire, but a compressor is obviously the thing to have.
Its then possible to connect up the air line with 10psi to the top of the fluid reservoir. That's plenty of pressure to really push fluid right through the whole system and out of each bleed nipple.
Post by zoona on Jun 4, 2021 21:28:28 GMT
I bought one of those aged ago, but it didn't come with the right size bloody cap, and I don't have a compressor any more
I might get a spare cap and modify what I have to fit.
What I have learned: Vacuum ones are prarrie canoe. Pressure is the way to do it It is possible to do it with a bit of hose on your own, but I am too much of a control freak for that. I want to see it. I prefer to rope somebody else in to help me
