nix
Doing hot girl s**t
Post by nix on May 20, 2021 14:12:47 GMT
anyone know of somewhere that can shorten and balance a propshaft, preferably in Sussex?
Post by dickie on May 20, 2021 17:22:07 GMT
I shortened a cortina propshaft to fit a Mk1 Escort, I wrapped a sheet of paper around it to mark a square cut for the length. I cut it just after the weld at the nose which was then set up in a lathe to square it up then the two bits were put back together making sure the joints were aligned properly then it was welded up. It was not balanced but the car would do just over 100 mph with no vibration from it.
Post by wannabe on May 20, 2021 20:04:31 GMT
Basset Down Engineering?
nix
Doing hot girl s**t
Post by nix on May 21, 2021 8:47:04 GMT
I shortened a cortina propshaft to fit a Mk1 Escort, I wrapped a sheet of paper around it to mark a square cut for the length. I cut it just after the weld at the nose which was then set up in a lathe to square it up then the two bits were put back together making sure the joints were aligned properly then it was welded up. It was not balanced but the car would do just over 100 mph with no vibration from it. I had considered doing it myself but the engine is going to be putting down 450-500HP and although I trust my welding ability I would not trust an unbalanced prop at high RPM with that sort of load.
nix
Doing hot girl s**t
Post by nix on May 21, 2021 8:48:43 GMT
I didn't see it listed as a service on their site but I've dropped them an email so will see what comes of it Thanks, Nicole
Post by dickie on May 21, 2021 16:05:53 GMT
Post by cardo on May 21, 2021 20:22:25 GMT
Not particularly close to Sussex unfortunately.....I used to use propshaft services in Feltham near Heathrow airport when I lived down South. propshaft-services.co.uk/
