Post by onepaintedman on Feb 27, 2022 14:58:46 GMT
Pulled #1 Plug again and cranked it over. There was a spark but as I leant forward to check the colour there was a big backfire up through the plug hole!
Post by atlex on Feb 27, 2022 15:20:11 GMT
a click may not be enough, I've had one that clicked but wouldn't give enough current to run the pump properly (low fuel pressure). ignition/timing if you do have some fuel on the plugs. cas ? also did you check the big ignition relay under the dash ? it's much bigger than the B6S8, I think it's called B577. I've ordered both B6S8 and B5S4 relays to rule them out of the equation. Woo
Post by zoona on Feb 27, 2022 16:16:00 GMT
Anyone know what this plug is for? It's on the same branch of the loom as the coil pack connector. O2 sensor?
Post by Zed. on Feb 27, 2022 19:58:40 GMT
So I don't forget again. . . fill the fuse socket with sillycon or 'poxy resin, then theres no chance of oopsies again Anyone know what this plug is for? It's on the same branch of the loom as the coil pack connector. the singlewire 02 sensor? Rich.
Post by dadbif on Feb 27, 2022 21:58:06 GMT
Wot Rich said, lambda sensor
Post by onepaintedman on Feb 27, 2022 22:51:17 GMT
Cheers guys. That would explain why I can't find anything to plug it in to, as I have an Innovate LC-1 wideband sensor installed.
š
Post by dadbif on Feb 28, 2022 8:16:11 GMT
I used it to connect my LC2 when wiring in megasquirt.
Post by onepaintedman on Mar 3, 2022 12:30:02 GMT
Update: it's not the B6S8 relay. No change with replacement.
I'm going to replace the CAS this weekend and see if that helps as I have a spare in the garage. I also have a spare Cam cover (and seal), so will cut that to expose the CAM gears and spray it up at the same time.
Post by onepaintedman on Mar 5, 2022 17:05:06 GMT
FFS. Tried to do the CAS replacement quickly to check that was the issue.
Removed CAS. Couldn't get it out without removing the coil pack.
Then couldn't get new one in.
Ended up removing cam cover anyway to refit CAS.
Then realised I hadn't marked the CAS position before removal.
Got it all refitted (approximated timing for now)
Car still won't start, but backfired. . . Twice.
š¤¬
Post by Zed. on Mar 5, 2022 19:12:23 GMT
Car still won't start, but backfired. . . Twice. well, it's a start (excuse the pun.) Rich.
Post by onepaintedman on Mar 6, 2022 9:09:37 GMT
Cam cover off again this morning to check belt. 19 theeth between cam wheel marks and everything aligned. WtF is wrong with my car? ?? This is why I gave up last time, but I will not be beaten!
Post by swordspork on Mar 6, 2022 10:50:38 GMT
Just a guess here could it be the ignititer? (Not sure of exact name). In the picture above it is to the right of the fuse box.
Post by onepaintedman on Mar 6, 2022 10:57:19 GMT
Just a guess here could it be the ignititer? (Not sure of exact name). In the picture above it is to the right of the fuse box. That's bizarre - I was literally just googling about the ignitor when you posted that message. I'm wondering if my ignition settings (dwell time, etc) have burned it out. It was never quite the same after I uprated the injectors to RX8 Yellows (435cc) which suggests I may have fiddled with something I shouldn't have done. It's been so long since I did the tuning and all my MS2 research I've forgotten everything and even though tunerstudio will now connect I'm not sure if my settings are correct or not anymore! Really bloody frustrated with this.
Post by zoona on Mar 6, 2022 12:45:44 GMT
Do you have anybody who can give you a fresh pair of eyes, and come over and make you go through everything from the beginning?
It's really easy to overlook things when you have been staying at our like a madman.
Post by onepaintedman on Mar 6, 2022 14:22:19 GMT
Do you have anybody who can give you a fresh pair of eyes, and come over and make you go through everything from the beginning? It's really easy to overlook things when you have been staying at our like a madman. Not really. I think the issue may partly be my settings in Tunerstudio/on the MS2. Going to post them online and see if anyone can see something obvious that I'm missing. Can't refer to my old tune/basemap, as it's on a laptop I've forgotten the password to.šµ
