Post by rich5660 on May 7, 2016 0:51:40 GMT
Today made me happy
Post by FFS Corders on May 7, 2016 11:51:10 GMT
looks like fun
Post by atlex on May 7, 2016 14:39:49 GMT
Upgraded to the latest ME221 firmware. startup/idle improved! D: wish ME would state the firmware upgrade path clearly. Had to use an old version of their tuning software to upgrade the firmware..
Post by mplsblack on May 7, 2016 16:31:53 GMT
Filled the tank with the "good stuff" and then went out and used it.
Post by Dweenimus on May 7, 2016 17:46:42 GMT
Drove it to a triumph meet. Triumph meet was a bit of a bust as it is actually happening tomorrow, only people there were the campers for tomorrow.
Post by BikeTuna on May 7, 2016 19:48:46 GMT
I changed my dash lights from factory red to LED blue...
Easiest dash change I've ever done!
Post by atlex on May 7, 2016 20:27:30 GMT
Rest of the arvo..
Fitted a jass brake stopper (pita to install.. those bolts going into the brake booster are pigs) Switched to a std yellow brace (good design, IMO) Flushed the PS fluid drove it to a cricket match drove a hillclimb (you know the one dweem) drove home preparing some foam to fill the gap infront of the rad..
Post by Dweenimus on May 8, 2016 15:48:13 GMT
Whee hillclimb. I need to do that again. Went to the Triumph meet. Took a picture. Was told "you're kind of a classic, you don't need to park with the modern cars"
Post by atlex on May 8, 2016 16:20:29 GMT
moved and emptied my catch can
which while I was doing so leaked a little juice onto my some 'relatively new' paintwork..
instant orange-peel. never seen a reaction so fast.
the catch was nearly full after 500 miles.... eek. need to empty it more often or fit an 'easy drain' tap to the bottom.
Post by onepaintedman on May 8, 2016 16:44:41 GMT
Rest of the arvo.. Fitted a jass brake stopper (pita to install.. those bolts going into the brake booster are pigs) Switched to a std yellow brace (good design, IMO) Flushed the PS fluid drove it to a cricket match drove a hillclimb (you know the one dweem) drove home preparing some foam to fill the gap infront of the rad.. If you've not got a supercharger the standard brace is the best I've come across. Fitted the exhaust yet? My new ones fubar'd. Hit a block of limestone in the road and completely reshaped the mid-pipe silencer!
Post by zoona on May 8, 2016 17:32:21 GMT
Moved gauges to crash pad in prep for nexus installation. I even took the time to wire up the illumination, so I might be able to see the oil temp in the dark now, which is nice.
Post by atlex on May 8, 2016 18:32:14 GMT
New exhaust goes on this week bring teh noises!!
Post by atlex on May 8, 2016 18:34:08 GMT
Whee hillclimb. I need to do that again. Went to the Triumph meet. Took a picture. Was told "you're kind of a classic, you don't need to park with the modern cars" I'm starting to work out where the 60s/70s GTR fashion of weird headlights comes from :-) so sexy. and ANGRY!
Tom
Post by Tom on May 8, 2016 18:49:47 GMT
Raised the front up a tad so it's not rocking mad rake Cleaned it very thoroughly Got some petrol Got it dirty/murdered hordes of flies Turned my back a very angry shade of red
Post by atlex on May 9, 2016 10:14:10 GMT
Managed to kill a westco battery. Wondering if I can coax it back to life...
