Post by Horney on Nov 3, 2016 12:28:08 GMT
Up for sale is my complete Mini Cooper S supercharger kit as fitted to my 1.6 Eunos.
What you get:
Mini Cooper S Teflon supercharger with 16% reduction pulley Supercharger mounting Bracket Supercharger Inlet pipework with airfilter and 2nd Throttle Body Standard 1.6 Throttle Body with spindle for 2 throttle cables Supercharger outlet pipework Supercharger Belt Idler and tensioner pulley system Walboro high flow fuel pump JDM 4 branch manifold with heat mat Front Mount Intercooler Intercooler hard pipes for over the radiator fitment Silicon Intercooler pipework connectors and reducers MS2 PNP for a 1.6 MK1 with a map on it RX8 yellow Injectors Both throttle cables Boost gauge All the clamps required All the vac lines for the boost gauge and ECU Correct spark plugs for boost
On my knackered 260,000 Km engine this made 189 bhp at the wheels so circa 220 at the flywheel.
There's probably some small bits I've forgotten to list but it is essentially everything you need to supercharge your 1.6 MK1. All you'll need to do modification wise is lower and tilt back your radiator for the boost pipes and bridge the fuel pump relay via the diag box. You might also want to upgrade your clutch. That's the only thing I'm re-using in my new build.
£2000 firm collected from Skuzzle Motorsport (who can no doubt fit for you as well). It'll be all stripped off the car by the end of November.
