Post by Rickster on May 23, 2017 21:42:55 GMT
so I had a v small leak from front of the engine, could be cam cover gasket or cam oil seals, thought I'd do both and managed to do the cam seals without removing the belt. Every how to guide I have seen says you have to remove the belt but with the locking tool from Mxparts or eBay and some cable ties plus a bungee to keep the tension on the belt you can remove the cam gears and move them out the way far enough to hook the old seals out and replace. So quick and easy! Splendid😃
