Post by stiff on Nov 10, 2017 10:10:13 GMT
I've just managed to shear an engine mount bolt off in the block. On a scale of one to "just set fire to the car" where do I stand?
Post by stiff on Nov 10, 2017 10:17:17 GMT
Just to add to the drama. It's the same bolt that hold the starter. I'm guessing this is terminal?
Post by melx5 on Nov 10, 2017 12:12:35 GMT
If you can get to it could you weld a nut to the end of offending bolt, heat should crack the corrosion and the nut will let you wind it out
Post by stiff on Nov 11, 2017 18:38:14 GMT
If you can get to it could you weld a nut to the end of offending bolt, heat should crack the corrosion and the nut will let you wind it out thank you for the reply. I ended up getting it drilled out and retapped. 😀
