khare
Post by khare on Feb 27, 2018 19:45:12 GMT
Looking for a genuine Mk1 1.6 headgasket, MX5parts has no stock for at lest 4 more weeks. Autolink do have some but they're almost twice the price as MX5parts.
Are there any other places I can buy a genuine gasket from that won't be ridiculously priced?
Post by Horney on Feb 27, 2018 20:32:41 GMT
Stupid question but have you tried Mazda?
khare
Post by khare on Feb 27, 2018 20:37:58 GMT
Stupid question but have you tried Mazda? Good shout mate, why didn’t I think that? Will call them tomorrow.
Post by wannabe on Feb 28, 2018 0:02:20 GMT
Moss might do them as well Or Skuzzle / Blink / TotalMX5 / The MX5 Restorer might have one in their parts stock they might be willing to sell you?
khare
Post by khare on Feb 28, 2018 9:01:03 GMT
£56 from dealers. Ta Nick!
Post by Horney on Feb 28, 2018 9:35:39 GMT
No probs.
Post by schercheeroo on Mar 1, 2018 19:49:12 GMT
Looking for a genuine Mk1 1.6 headgasket May I ask why? did something bad happen?
khare
Post by khare on Mar 1, 2018 23:19:35 GMT
Looking for a genuine Mk1 1.6 headgasket May I ask why? did something bad happen? Oil is pi$$ing outnif it down the back of the engine.
Post by dadbif on Mar 3, 2018 13:02:06 GMT
Sure it’s the head gasket?
khare
Post by khare on Mar 3, 2018 15:26:47 GMT
Pretty adamant. Head is dry, block isn’t. I’ve insoected it all and cleaned it all up but still same issue
Post by dadbif on Mar 4, 2018 13:01:04 GMT
If it’s the rear of the head it could be coming from the CAS
khare
Post by khare on Mar 5, 2018 8:40:53 GMT
If it’s the rear of the head it could be coming from the CAS Head is dry, I changed cas seal a few months ago along with valve cover gasket.
Post by dadbif on Mar 5, 2018 11:23:44 GMT
The oil feed from the block to the head is just above the filter, not near the back. I would still bet on the CAS, I am about to change mine for the second time...
khare
Post by khare on Mar 5, 2018 12:42:07 GMT
The oil feed from the block to the head is just above the filter, not near the back. I would still bet on the CAS, I am about to change mine for the second time... There’s 3 oil galleys that flow oil, 2 at the back, onenin each corner and one at the front corner exhaust side. There’s been plenty of mx5’s that have suffered leaks there. It’s not the case as the front of the block is also wet, plus I’m losing about 1l of oil a week. CAS wouldn’t be such a big leak.
Post by dadbif on Mar 6, 2018 7:53:15 GMT
The only pressurised oil feed is where I described it, all the other galleries between the head and block are simply drains back to the sump. Good luck with the gasket change, I’d do the cam cover and CAS O ring at the same time though.
