Post by Zed. on Dec 20, 2018 17:47:12 GMT
Okey, I admit it... I'm a bit lazy..... so... as I do not have my car in bits.... does anyone have an NA 1.6 flywheel accessable & could they measure the clutch surface - or maybe a clutch plate (inside & outside diameters) please Also... does anyone know what the standard flywhees are made from? (cast iron or steel?) Thankyou. Rich.
Post by cardo on Dec 20, 2018 18:18:06 GMT
1.6 flywheel is cast iron I’ve got a couple in the shed, if you don’t mind waiting till Saturday I can measure the friction surface dimensions for you.
Post by Zed. on Dec 21, 2018 0:28:46 GMT
1.6 flywheel is cast iron I’ve got a couple in the shed, if you don’t mind waiting till Saturday I can measure the friction surface dimensions for you. appreciated Rich.
Post by cardo on Dec 22, 2018 20:06:13 GMT
Hi Rich
1600 flywheel face is 38mm from inner edge to outer.
