Post by rsnick on Jan 8, 2019 22:51:09 GMT
I need some supercharger oil, where is the best place to get some from?
cheers
Nick
Post by dadbif on Jan 8, 2019 23:00:55 GMT
Halfords, Mobil 1, I have used it for 3 years with no ill effects, changed it a fortnight ago, needn’t have bothered, like new.
Post by Zed. on Jan 8, 2019 23:51:15 GMT
sensible cost or silly? sorta just bought a merc m45 so looking into usefull stuff... Rich.
Post by cardo on Jan 9, 2019 11:30:32 GMT
If it’s oil for the nose of the charger you’re looking for i wouldn’t use Mobil 1. Mobil Jet 11 or BP2380 are the correct spec.
Post by dadbif on Jan 10, 2019 7:07:42 GMT
Whatever you use, be aware that you may have to adjust the oil content, the m45 (cannot comment on others), is located in a position different to its designed installation, so the oil contained in the bearing housings is at a non standard level when fitted to our cars.
Post by jackyboy on Jan 20, 2019 11:07:59 GMT
Mine could do with this. Any tutorials?
Post by Horney on Jan 21, 2019 12:05:31 GMT
Post by rsnick on Jan 23, 2019 12:38:50 GMT
Great! Will this be suitable for the '62'?
cheers
Nick
Post by dadbif on Jan 23, 2019 13:12:09 GMT
Re step 12, hence my comment about adjusting the oil content, the charger is on its side in our application so would not contain as much oil if filled in situ, if you fill it level then the oil level is below the bearings when fitted and will rely on oil splashed up by the index gears. However, I think the snout bearing relies more on mist lubrication than actual immersion...
Post by Horney on Jan 23, 2019 21:44:18 GMT
Great! Will this be suitable for the '62'? cheers Nick Good question and I'm afraid I don't know.
Post by martiny on Jan 24, 2019 22:23:04 GMT
I changed my '62 oil and coupler some years ago and I recall that the correct amount of oil was frustratingly just over half a bottle (so you couldn't get 2 changes from 1 bottle). It was something like 120ml from a 200ml bottle. Somewhere in the garage I've still got that bottle, so I'll search it out when I can (bit under the weather at the moment but when I'm betterer).
Post by rsnick on Jan 26, 2019 0:49:49 GMT
I changed my '62 oil and coupler some years ago and I recall that the correct amount of oil was frustratingly just over half a bottle (so you couldn't get 2 changes from 1 bottle). It was something like 120ml from a 200ml bottle. Somewhere in the garage I've still got that bottle, so I'll search it out when I can (bit under the weather at the moment but when I'm betterer). Hi Martin, your on here too!
Just what I need to know! Your turn with the horrible virus then! Get well soon. I was after the volume needed and probably need the oil seal as advertised in the Mini kit just to be safe.
Hear from you later!
cheers
Ncik
Post by martiny on Jan 27, 2019 13:26:52 GMT
Hiya Nick. I still haven't got as far the garage but now I'm not so dizzy/nauseous I searched old emails and found it's 110ml of oil for the nose of our MP62s. Quite a bit less than a Mini blower. Hope that helps.
