Post by binner on Oct 20, 2021 8:41:19 GMT
hello
I am messing around with suspension on my mk2.5.
i want to see what fitting a downgraded arb to the rear and upgraded arb to the front will do to the handling
ideally i would remove the rear arb but the regs of the competition I take part in does not allow that.
If any one has a mk1 1.8 stock rear anti roll bar for sale let me know
gbuk
Post by gbuk on Oct 20, 2021 12:00:00 GMT
hello I am messing around with suspension on my mk2.5. i want to see what fitting a downgraded arb to the rear and upgraded arb to the front will do to the handling ideally i would remove the rear arb but the regs of the competition I take part in does not allow that. If any one has a mk1 1.8 stock rear anti roll bar for sale let me know I've got one you can try. I'm in WsM and you're local too IIRC?
Post by binner on Oct 20, 2021 15:16:49 GMT
I am in Bristol so yes local ish.
are you at Combe on Saturday ? I am at the sprint there
gbuk
Post by gbuk on Oct 20, 2021 16:12:17 GMT
Unfortunately not, I would have liked to come along and marshal again, it was a fun day when I did a couple of years back. I'm usually in and around Bristol a few times a week so drop me a PM and we'll get something sorted.
jimb
Post by jimb on Oct 20, 2021 19:05:27 GMT
The regs say anti roll bars may be upgraded. If you think no anti roll bar is an upgrade, surely it is allowed?
Post by Zed. on Oct 20, 2021 21:37:00 GMT
early ~1989 cars had a thinner rear arb alegedly Rich.
Post by dickie on Oct 21, 2021 16:45:47 GMT
How about leaving the ARB in place and just removing one drop link so that the bar will just move with one wheel !!!! It will fullfill the regs if its fitted and attached.
Post by binner on Oct 22, 2021 12:12:06 GMT
The regs say anti roll bars may be upgraded. If you think no anti roll bar is an upgrade, surely it is allowed? chatting to my fellow competitors and the coordinator at the solo last weekend the feeling was no taking off bits unless you are adding something to replace it so removing and ARB is fine as long as you fit another :-) it may make the feel car worse so just an experiment The logic comes from the US Autocross scene which may not apply here here is a discussion about it forum.miata.net/vb/showthread.php?t=362012
Post by howardb66 on Oct 22, 2021 14:49:53 GMT
The regs say anti roll bars may be upgraded. If you think no anti roll bar is an upgrade, surely it is allowed? chatting to my fellow competitors and the coordinator at the solo last weekend the feeling was no taking off bits unless you are adding something to replace it so removing and ARB is fine as long as you fit another :-) it may make the feel car worse so just an experiment The logic comes from the US Autocross scene which may not apply here here is a discussion about it forum.miata.net/vb/showthread.php?t=362012When Hillclimb Ins the TVRs, we used to just take a bolt off one end.😁
