Post by madbean on Aug 30, 2016 12:31:15 GMT
Post by myothercarsa2cv on Aug 31, 2016 11:23:30 GMT
Save your money on that fancy airbox. If it's just sound, then bolt a cone filter on the maf.
If you want an intake that works, the standard plus aftermarket panel filter plus Randall cowl intake if you are so inclined to drill a hole in your bulkhead.
Otherwise standard plus panel filter. If you wanted you could run some donkey Canoe to the front of the car.
Post by FFS Corders on Sept 2, 2016 22:38:42 GMT
Drill the standard airbox on rhe side before the air reaches the filter
You get that ebay filter noise at a fraction of the cost
Post by madbean on Sept 3, 2016 4:58:57 GMT
fitted a K&N panel filter and will drill some holes
