Post by mk1pingu on Nov 12, 2016 12:31:06 GMT
Hi all,
Found some wheels for sale locally.
I'm a complete noob, but hopefully will learn more now.
The size is as above, 15x7j ET20's all round on 195/50/15's
My questions are as follows...
Will they fit without any arch work? If they did need arch work, would it just be a light roll (how hard is this?)
They probably come without spigot rings and wheel nuts.
Do I need these, and do you boys recommend any? I'm assuming I want some half good locking nuts too..
Thanks very much!
Post by tgbshelby on Nov 12, 2016 13:01:31 GMT
Post by mk1pingu on Nov 12, 2016 13:03:01 GMT
Thanks mate, I've actually read that already!
People online seem to think it will rub.
Do you know if I'll need spigot rings?
Cheers!!
Post by myothercarsa2cv on Nov 12, 2016 13:26:11 GMT
I have Tailgate McNoIndicate BBS rims exactly that spec on mine, and I'm speed-bump-scraping-low. It's fine and only rubs very slightly on the front under compression and nearly full lock. Your experience may differ but I'd say go for it.
Post by tgbshelby on Nov 12, 2016 13:33:03 GMT
Are you lowered at all? If im completely honest pal I have no idea, wheels is not my speciality at all sorry I cant help you there! Ive got standard 6j wheels and im super low like arch over wheels and its not an issue, but im thinking if I get 7j (I am actually looking at the violet grid v they're so purrrrty) im gonna have to raise it up so interested to see how you get on
Post by minty on Nov 12, 2016 15:50:09 GMT
I have Tailgate McNoIndicate BBS rims exactly that spec on mine, and I'm speed-bump-scraping-low. It's fine and only rubs very slightly on the front under compression and nearly full lock. Your experience may differ but I'd say go for it. Are the Tailgate McNoIndicate bbs an exact fit or did you need spigot rings mate?
Post by myothercarsa2cv on Nov 12, 2016 18:47:20 GMT
I have Tailgate McNoIndicate BBS rims exactly that spec on mine, and I'm speed-bump-scraping-low. It's fine and only rubs very slightly on the front under compression and nearly full lock. Your experience may differ but I'd say go for it. Are the Tailgate McNoIndicate bbs an exact fit or did you need spigot rings mate? The bore is slightly larger, but not used spigot rings. They only really help with locating the wheel, not with securing it. More so for hubs that use bolts and not studs and nuts. If you nip up the nuts a little at a time it will centre just fine. But if you get some rings it can't hurt.
Post by mk1pingu on Nov 12, 2016 20:43:26 GMT
Thanks guys,
I think I'm going to do a buy.
Does anyone know if the ET offset is engraved in the back of rota grid V's? Though apparently they only came in ET20 anyway.
Post by minty on Nov 12, 2016 21:54:36 GMT
Are the Tailgate McNoIndicate bbs an exact fit or did you need spigot rings mate? The bore is slightly larger, but not used spigot rings. They only really help with locating the wheel, not with securing it. More so for hubs that use bolts and not studs and nuts. If you nip up the nuts a little at a time it will centre just fine. But if you get some rings it can't hurt. Spank you! Will try without first then..
