Post by chris71 on Dec 14, 2016 19:09:56 GMT
Evening guys,
whilst removing the diff today I have sheared a bolt. Looking to sell this on as is in superb condition with no rust issues and has the brackets for the lower brace. What's the best way to sort this F up I've made.
Many thanks
Chris
Post by Horney on Dec 14, 2016 23:09:20 GMT
Can you post a couple of pics so we can see which one and how bad?
pewe
Post by pewe on Dec 15, 2016 9:02:16 GMT
If penetrating oil fails then heat is probably the answer. As Horney says ^^ pics will help so the coolective (sp?) can see what/where and offer further advice. Cheers, Pewe.
Post by chris71 on Dec 15, 2016 10:09:28 GMT
will up load pictures later
Post by chris71 on Dec 15, 2016 16:31:32 GMT
As promised picture of offending item Kinda guess would need to be drilled out.
Post by Rickster on Dec 15, 2016 16:57:22 GMT
On my old 5 i just ground it off and didnt replace, doesnt it just locate a clip for something, I remember thinking it wasnt massively important!!
Post by martiny on Dec 16, 2016 12:00:05 GMT
It's one of the two studs that hold the plate covering the bottom of the diff mount. Never really though about it but I suppose it's to provide lateral support for the free end of big stud that goes through the diff mount. I guess one bolt is probably okay but not ideal if you intend to sell it on.
The obvious repair would be to drill it out, put a bolt through the hole and tack weld its head into place. (Or sell it as-is and let the buyer repair it by drilling and using a nut and bolt instead.)
Post by Rickster on Dec 16, 2016 12:16:41 GMT
I think I left mine with one and the car is still going strong years later with no issues AFAIK
Post by chris71 on Dec 16, 2016 17:26:02 GMT
Thanks for the input guys. Think I'll sell it as is, don't have access to a welder and doubt it would be worth the cost of me getting it sorted as see some have sold on evilbay for £15. Will do some checking. Is 1990 frame and has the brakets for the lower brace so maybe worth something to someone.
