Post by wannabe on Jan 20, 2017 13:42:33 GMT
Post by josho on Jan 20, 2017 15:03:11 GMT
You can adjust the tensioning of the pinion to the rack, should get rid of the slop
Post by wannabe on Jan 20, 2017 17:33:03 GMT
Thanks!
I need to dig out the service manual thing so I can get my head around the 'blown apart' pictures lol
Post by tropical on Jan 20, 2017 18:13:27 GMT
Definitely check the UJ at the bottom of the column, if the pinch bolt is loose the steering column shaft will have play in it but will not go further than the flats on the shaft. Drive the car up on some ramps and get someone to jiggle the steering wheel while looking very carefully at the UJ. Free fix if it is this, it was on mine.
Post by Horney on Jan 20, 2017 18:42:39 GMT
I've got a good used rack you can have for £20.
Post by wannabe on Jan 21, 2017 10:06:05 GMT
Thanks for the replies, chaps I recall the pinch bolt being mentioned before - I want to get it booked in at skuzzle as I think the timing's out, so I'll get it serviced and the column looked at while I'm there! £20 is a bargain price for a rack, Horney, so thank you for the offer I may well take you up on that, depending on the outcome of investigations!
Post by Horney on Jan 21, 2017 17:27:49 GMT
Thanks for the replies, chaps I recall the pinch bolt being mentioned before - I want to get it booked in at skuzzle as I think the timing's out, so I'll get it serviced and the column looked at while I'm there! £20 is a bargain price for a rack, Horney, so thank you for the offer I may well take you up on that, depending on the outcome of investigations! Well it's at Skuzzles so if you want it when you're there just let the hippy or Amish know.
Post by wannabe on Jan 22, 2017 12:38:29 GMT
Thanks for the replies, chaps I recall the pinch bolt being mentioned before - I want to get it booked in at skuzzle as I think the timing's out, so I'll get it serviced and the column looked at while I'm there! £20 is a bargain price for a rack, Horney , so thank you for the offer I may well take you up on that, depending on the outcome of investigations! Well it's at Skuzzles so if you want it when you're there just let the hippy or Amish know. Haha Awesome, will see what finances are like after payday and hopefully get it booked in. The windscreen surround de-rusting work is going to be more expensive than planned, I reckon, so might have to wait!
More money would fix a lot of things... lol
Post by wannabe on Apr 23, 2018 13:32:54 GMT
Thanks for the replies, chaps I recall the pinch bolt being mentioned before - I want to get it booked in at skuzzle as I think the timing's out, so I'll get it serviced and the column looked at while I'm there! £20 is a bargain price for a rack, Horney , so thank you for the offer I may well take you up on that, depending on the outcome of investigations! Well it's at Skuzzles so if you want it when you're there just let the hippy or Amish know. Sooooo...
To ask a ridiculous question, is your rack still down at skuzzle? lol
