Post by Rickster on Feb 7, 2017 15:24:23 GMT
Used GRP seat - i fixed a spare set of standard runners to it (properly with 3mm anchor plates) so its easy to swap back to my leather heated jobbie. Impressed with the Prima Motorsport Titon 6 point FIA harness, not expensive but nicely made and fits well. Had a drive in it and it was quite comfy considering (i'm 6ft and 14 stone)! cant wait to try it on track now
Post by BikeTuna on Feb 8, 2017 8:20:52 GMT
Looking good, but 6 point harness? it'll take you 1/2 hour to get in and out of it!
Post by Rickster on Feb 8, 2017 11:20:44 GMT
No, its easy - the submarine belt is permanently fixed to the buckle, insert the lap belts, then shoulder belts - pull tight all done. turn the handle - all 4 come undone, quicker than the standard belt to get out! Also with a spare set of runners fitted to the bucket I can swap back to the standard seat in about 10 mins anyway. I have found a couple of problems - be sure to close the door BEFORE you do the harness up! and at acute angle junctions you cant lean forward to look back - but thats probably why you should have intertia belts fittd for MOT:D
Post by minty on Feb 8, 2017 19:45:20 GMT
My fat ass never seems to fit in these sorts of seats - looking great though!
