Post by Woofwoof on Feb 26, 2017 22:32:34 GMT
Guys, where is the best place to get a new one - NB 1.8 A/C. I've looked on eBay and the specialist suppliers, the price varies a lot.
Any advice gratefully received.
Post by Dweenimus on Feb 27, 2017 7:43:45 GMT
I just bought the fast5.co.uk ally rad for £139 on a group buy on almonds
Post by myothercarsa2cv on Feb 27, 2017 9:33:37 GMT
I bought a Fast5 for my NA, straight drop-in fit, no hassle. Good company to deal with, which is worth the extra over eBay in my opinion.
Post by curlyteeth on Feb 27, 2017 13:42:24 GMT
I've got a 1.8 NA rad but I don't know if they are interchangeable??
Curlyteeth
Post by Woofwoof on Feb 27, 2017 15:16:31 GMT
Curlyteeth Thanks for mentioning that. I don't know either about NA-vs-NB rads Is yours a new standard rad or larger capacity all alloy one?
Post by curlyteeth on Feb 27, 2017 21:26:21 GMT
Its a standard Rad from a 97 NA that I dismantled after buying it for parts - it had a Supercharger setup amongst other things that wanted but the car had stood on cliff top on the south coast for 3years and body was totalled. the rad looks fine though, when I took it off it was full of coolant - I took every thing I could carry - right down to the engine, gearbox and LSD.
Curlyteeth
Post by myothercarsa2cv on Feb 27, 2017 22:41:44 GMT
Different mounting points. Although you could probably make it work...
Post by Woofwoof on Feb 28, 2017 10:10:20 GMT
Its a standard Rad from a 97 NA that I dismantled after buying it for parts - it had a Supercharger setup amongst other things that wanted but the car had stood on cliff top on the south coast for 3years and body was totalled. the rad looks fine though, when I took it off it was full of coolant - I took every thing I could carry - right down to the engine, gearbox and LSD. Curlyteeth Thanks again Curlyteeth. I'll leave it you don't mind. I decided to opt for a new rad, just got to decide between a standard Nissens (£60) or a larger all alloy from the likes of Fast5. Cheers.
Post by tropical on Feb 28, 2017 16:32:11 GMT
I bought the cheapest eBay alloy rad from eBay for my mk1. It looks VEEERY similar to other higher priced alloy rads. I would be very surprised if it wasn't made in exactly the same Chinese factory.......... 😗 Performs perfectly.
Post by josho on Feb 28, 2017 16:59:53 GMT
Another vote for Fast5 here
Post by Woofwoof on Feb 28, 2017 21:31:12 GMT
Another vote for Fast5 here Would you know if Fast5 make their own?
Post by Woofwoof on Mar 1, 2017 14:51:32 GMT
O.k. guys, in the end I didn't bother with an larger all alloy rad as I reckoned it was bit overkill for just ordinary road use on a standard engine. I ended up buying a new Nissens radiator for 67 quid which I'm happy with and if I do at some stage decide to track the car I'll get a larger rad then.
Thanks again.
