Post by trikkisixx on Mar 17, 2017 16:57:04 GMT
Should have just used double sided tape! Or gaffa tape!! or buy a hat for his girly hair!! Lol lol I own many a hat!
Post by minty on Mar 17, 2017 20:13:39 GMT
A man of means is trikkisix
Post by FFS Corders on Mar 17, 2017 20:28:32 GMT
Good reference for the future, well done trikkisix!
Post by tgbshelby on Mar 17, 2017 21:29:41 GMT
Should have just used double sided tape! Can't tell if serious or not? lol I was after something more permanent so will get the JASS brackets ordered next week once payday comes around There's a group buy on nutz which you can get cheaper brackets with some new replacement plates for frank bolts on the back, have a look might be worth it for the cheaper brackets price if nothing else!
Post by trikkisixx on Mar 18, 2017 11:56:23 GMT
Can't tell if serious or not? lol I was after something more permanent so will get the JASS brackets ordered next week once payday comes around There's a group buy on nutz which you can get cheaper brackets with some new replacement plates for frank bolts on the back, have a look might be worth it for the cheaper brackets price if nothing else! Thanks for the heads up chief!
Post by trikkisixx on Mar 29, 2017 10:07:16 GMT
By way of update, I got a set of side brackets from JASS. They fit the sides perfectly, (you do need to cut away some of the plastic trim however). They also fit the fronts but one of the holes does not line up so you will need to get a bit freaky with a file but it will work with some adjusting. If you have a rattly roof I cannot recommend these enough, makes such a difference!
