Post by BikeTuna on Mar 31, 2017 7:00:37 GMT
I've got hold of a factory front strut brace out of a 03 mk2.5 sport, and it bizarrely doesn't fit my 02 2.5?
If I fit it the right way round the NS bolt holes don't line up as the brake booster is in the way but about 3-4mm. If I fit it the wrong way round the bonnet doesn't close.
How am I getting 4 simple bolts wrong?
Post by Rickster on Mar 31, 2017 7:03:31 GMT
Isn't the brake booster aftermarket - is that the problem? I believe brake boosters can interfere with strut braces?
Post by BikeTuna on Mar 31, 2017 7:47:30 GMT
Pretty sure its a standard setup, though not sure if mine will have a different brake setup to a sport model and that the booster valve thing would be affected by that.
Post by AndyMk2 on Mar 31, 2017 8:04:54 GMT
Booster may be different on the sport due to the larger brakes setup, possibly?
Post by Rickster on Mar 31, 2017 9:05:39 GMT
Soz i was being dense - i thought the brake booster was the added bracket supporting master cylinder! I'll shutup!
Post by Horney on Mar 31, 2017 9:55:19 GMT
Post some pics.
Post by BikeTuna on Mar 31, 2017 15:07:01 GMT
Cant do that from work as nowhere to upload to, will hopefully do that later on. Ta
