Post by howardb66 on May 15, 2017 8:12:29 GMT
Is anyone else competing at Prescott on the 27th? My brother & I are double driving our car, the goal is to get in the 51/50 sec range.
Post by howardb66 on May 19, 2017 15:51:04 GMT
Just got the entry through, there's some interesting stuff competing-
Fiat 'Beast' 28,450cc vintage racer (it's worth going just to see this!!)
8 Bugattis
A Ferrari Class incl a 250 GT Lusso
oh & 6 MX5s....
Post by sandys on May 19, 2017 16:27:53 GMT
Reckon you'll hit your target, I might come down and spectate, its not far, be good to see how others attack it.
Post by howardb66 on May 19, 2017 17:12:13 GMT
Fingers crossed, hope to get somewhere between my 2016 MX5 MK1 time of 53.95 & my 2015 TVR time of 48.77 The weather forecast is looks reasonable, the food in the clubhouse is good & my brother is driving the car home so I can have a few beers, that's a win already!!
Post by apextwin on May 20, 2017 8:47:23 GMT
48.77 in the Trevor is a great time. What was the spec of the car? After some unofficial timing at the hillclimb school Id like to go sub 50 with mine.
Post by sandys on May 20, 2017 9:24:41 GMT
You do a lot of schools I tried to get in on the Gurston one before the HSA event but was told it's full. AIM Solo would help you time school days. I'm booked in to the HSA Prescott event in June, my last visit there it pissed it down for timed but my first hot run up the hill was a 53.6 so I am bound to be quicker as I doubt I nailed it in Practice, especially having not seen it before and having got there late and so didn't walk the hill, i'm targeting a 51/52 weather permitting.
Post by howardb66 on May 20, 2017 11:15:30 GMT
48.77 in the Trevor is a great time. What was the spec of the car? After some unofficial timing at the hillclimb school Id like to go sub 50 with mine. I've had the Griffith for 14 years so have got used to it's handling. It looks completely standard but underneath it's not.....
Post by howardb66 on May 27, 2017 18:42:15 GMT
2nd in classs & my brother came 4th out of 24. The diff was an issue again out of hairpins. More tat for the cabinet!
Post by Horney on May 27, 2017 18:43:03 GMT
Nice work.
Post by howardb66 on Jun 5, 2017 18:23:41 GMT
Post by baconsarnie on Jun 6, 2017 11:12:37 GMT
2nd in classs & my brother came 4th out of 24. The diff was an issue again out of hairpins. More tat for the cabinet! Tried disconnecting the rear arb?
Post by howardb66 on Jun 7, 2017 7:13:48 GMT
2nd in classs & my brother came 4th out of 24. The diff was an issue again out of hairpins. More tat for the cabinet! Tried disconnecting the rear arb? Tried in the paddock but it was very reluctant. Didn't want to damage anything so left it be. Now giving it regular soaks in oil & will have another go at freeing the little critter off.
Post by baconsarnie on Jun 7, 2017 8:06:08 GMT
Tried disconnecting the rear arb? Tried in the paddock but it was very reluctant. Didn't want to damage anything so left it be. Now giving it regular soaks in oil & will have another go at freeing the little critter off. I tried it last time out at Gurston and found it helped a lot with the hairpin wheel lift then wheel spin scenario No understeer as far as I could tell, managed to be flat thru hollow! I've concluded that once you get up to the spring rates a lot of the track orientated shocks are at the rear ARB isn't contributing much roll resistance but is reducing the amount of droop at the rear. I'm set up with 550lb front 335lb rear and a front RB ARB for reference
Post by Rickster on Jun 7, 2017 9:58:38 GMT
Im on the middle setting on the JR rear ARB - do you think i should try the outer (less stiff) setting for Gurston? I have the poor mans suspension - mk2 with one coil off, it is fairly stiff?
Post by baconsarnie on Jun 7, 2017 11:19:40 GMT
Hard to say for sure, but if your finding wheel spin out of ashes then I'd say yes and also try disconnecting altogether...
Believe the NB spring rates are in the region of 165lb fr 120lb rr for reference, not sure how removing a coil effects this.
