Post by chris71 on Jun 6, 2017 17:21:47 GMT
Hi, Need to change over one of the hubs and having had a look at Haynes manual they say to attach two lengths of steel to counter hold the hub flange whilst cracking the drive shaft nut. Is this a tool that can be bought or is it one of those "MacGyver" moments ? Thanks
Post by Horney on Jun 6, 2017 21:31:13 GMT
Hummmmm. Always done mine at Skuzzle and just buzzed the nut off with a windy gun. Getting the shaft out of the hub is another story all together.
Post by chris71 on Jun 7, 2017 13:52:13 GMT
Oh. The reason why I want to replace the hub is on of the studs has been cross threaded in the past, the bearing feels fine. Can the stud be replaced instead ?
Post by Rickster on Jun 7, 2017 14:48:42 GMT
Post by chris71 on Jun 7, 2017 16:19:55 GMT
Thank you Mr stickers. 👍 Added bonus I get to hit things with FBH !
Post by minty on Aug 22, 2017 10:56:00 GMT
Bumpy!
Did you do this in the end Chris? If so, how hard was it to get the stud out, and how did you press in the new one?
Cheers
Post by chris71 on Sept 8, 2017 17:32:54 GMT
Sorry Matt for delay
Not been on here for a little while. Easy peasy to do. just follow the link given by Mr Stickers. With regards to bedding the new one in, I just gently wound in the wheel nut. Weather that's the way it should be done or not, but it worked for me.
Post by minty on Sept 8, 2017 19:01:14 GMT
Sorry Matt for delay Not been on here for a little while. Easy peasy to do. just follow the link given by Mr Stickers. With regards to bedding the new one in, I just gently wound in the wheel nut. Weather that's the way it should be done or not, but it worked for me. Thanks Chris, I'm not much of a spannerer so that's good news.
