Post by chris71 on Jun 22, 2017 18:03:58 GMT
Hi. Have done the foam mod and taken out enough so the seats are still comfortable but would like to go a little lower, another 20mm give or take. Wanting to keep the original tombstone seats as apart a bit faded they're in top condition and at some point will be putting speakers in the head rests. What, if any are my options. Thanks
Post by wannabe on Jun 26, 2017 13:15:24 GMT
I think you're pretty limited with what to do - IIRC the standard seats can't be sidemounted, so you can't lose the height the standard rails result in, so your only option might be to bolt them directly to the floor with appropriate spreader plates??
Post by minty on Jun 26, 2017 18:53:56 GMT
I have the same issue, I NEED LOWER! I try to slide down to look cool (so my head isn't sticking up above the windscreen,) but then I just get a bad back Not done foamectomy yet tho to b fair.
