Post by jack on Sept 14, 2017 8:41:29 GMT
Hi all,
Just found this place, relatively new to 5's but have been through 2 already, here's my story so far:
This was the first 5 I bought, for a measely £500:
It was rotten as hell but was a good base for me to learn how to work on cars and to see if I enjoy MX5's.
I collected some parts
And took a few photos
Then the real fun began
Flyin Miata stage 1 from the USA
GCR2
Some rude arches with rolled on paint
This was its 'final state':
And then......
AND the headgasket went. Was looking at a big big job to fix both the rust and the engine, so I pulled all the bits off, scrapped the shell and bought this:
Went straight to work with Doug from G19 and ended up with:
Found some broken bits:
But also some Bilstein shocks!
Got the exhaust and wheels fitted:
The electric window broke, fully down, just before it rained:
Found some dodgy wiring and fixed it
And curbed a wheel!
Here she is now:
Current Spec:
1996 MX5 Mk1 1.8
Power Windows
Manual Steering
3.9 Torsen diff
IHI VF35 Turbo
G19 Cast Manifold
G19 Downpipe
G19 Decat
RX8 Injectors
Flyin' Miata stage 1 clutch
Sparco Sprint seats
OMP 6 Point drivers & 4 point passenger harnesses
Cobalt 2.5" cat-back
HSD Monopro Coilovers
15x8 ET0 Rota Grid
195/50 Toyo Proxes cRap
Current Issues:
Misfire > 6500RPM
Diff leaking oil
Brake pedal rumbles under hard braking (feels like warped disc)
Wheels poke out too much
Needs alignment
Parts ready to fit:
EBC Yellowstuff pads
Blueprinted discs
NGK heat rating 7 spark plugs
Jackson Racing HT leads
Diff side seal
GCR2 roll bar
So next I need to attempt to fit the new diff seal, having never really done anything diff related I'm a little aprehensive but it doesn't seem like the hardest job in the world. Also need to fit the new brakes to fix the pedal wobble, I might invest in a master cylinder brace as well at some point. The sketchiest thing on my list is the misfire, hopefully the new plugs + leads will fix the problem. Also need to either commit to selling/swapping these wheels and find something ET20ish OR roll the arches to fit the ET0 wheels under. Ideally I want some RPF1's but I don't think I can afford them at the moment.
Once its all ready (hopefully before the end of September) I'll be getting it on a track somewhere to give the car a proper shakedown and see how it performs.
GCR2
And then......
And curbed a wheel!
Here she is now:
Current Spec:
1996 MX5 Mk1 1.8
Power Windows
Manual Steering
3.9 Torsen diff
IHI VF35 Turbo
G19 Cast Manifold
G19 Downpipe
G19 Decat
RX8 Injectors
Sparco Sprint seats
15x8 ET0 Rota Grid
Current Issues:
Misfire > 6500RPM
Diff leaking oil
Needs alignment
Parts ready to fit:
Blueprinted discs
Diff side seal
GCR2 roll bar
