Post by myothercarsa2cv on Oct 1, 2017 20:40:50 GMT
I've taken the difficult decision to break Libby. She's a 1994 Mk1 Eunos (import) 1.8 S Limited (I think!).
All parts located in Bromley BR1.
Super mega tombstone gauge cluster. Consists of a Jass Performance double din fascia for three gauges above a single din slot. Comes with Autometer Pro Comp Ultralite clock, boost gauge and oil temperature gauge. Boost gauge has an adapter shipped from the USA to allow it to use a normal vacuum hose rather than the crappy nylon easily kinked hose it comes with. The green lights are not Autometer and are smaller than the holes in the back so are held in with tape. Hand made wiring loom so that you can easily install/remove, with 4-pin socket for switched live, permanent live, illumination, oil sender. Separate ground. Single din slot has a cubby hole bolted in. Cubby has a jack sized hole in the back for plugging in your phone. £135 Will split if no interest in whole. £30 for just the panel.
Fuel pump and sender assembly. FREE TO COLLECT.
Tail lights, each missing one stud. FREE TO COLLECT.
Welded diff no carrier. £50 collection only
Stormforce fitted cover, barely used. A few grubby marks from covering the car while breaking. £60 collection only.
Already sold:
Megasquirt MS1 enhanced PNP for ‘94 Eunos 1.8, complete with wiring loom, serial cable, serial to USB and serial to Bluetooth £350 SOLD
G19 063 battery clamp. Battery not included. £30 SOLD
Over the rad intercooler setup: Toyosports top feed cooler, silicone joiners, clamps and hard pipes for a mk1 1.8 inlet mani £130 SOLD
Banda Audio 250.2 amp. Includes RCA cables, gain control and Bluetooth receiver to go head unit free if you want! £80 SOLD
JDM rear number plate panel in red. £50 collection only. SOLD tsp
PPF. On eBay. SOLD
Made in Japan silicone 'Ultra' HT leads. Numbered for ease of install. Red for extra speed. £10 SOLD tsp
Headlight motors. £offers. SOLD
Passenger seat and rails and all fixings. Speakers and wiring removed. £FREE SOLD
Ashtray. Functional, could do with a refresh. £Free SOLD
Front wings, pair, red complete with side repeaters and fixings. £20 SOLD
Mk1 dashboard. £20 SOLD
Rear bumper, red, with fog light. £20 SOLD
Red bonnet £50 SOLD
Lightened OE flywheel, needs new spigot bearing, and what I believe is a Spec Stage 2 clutch which probably needs refacing. £10 SOLD
Red hardtop. £320 SOLD
Jass Performance brake stopper. For use without a strut brace. Stop the flex! £25 SOLD
Sunglasses tray (fits ashtray slot). £10 SOLD
Gear lever and lower boot. £FREE COLLECTED SOLD
Jass Performance 2” gear-lever extension in brushed silver. £10 SOLD Scottydoug
Sidelight/indicators. One needs resealing. £10 SOLD
Stainless sill kick plate cover things. On eBay. SOLD
Doing an AC delete? You'll need this. £5 SOLD boringgit
What I am told is an old style Carbing tow hook. £30 SOLD
Oil filter relocation kit by Mocal. £50 SOLD
1.8 brake calipers with nearly new Rodders pads all round. £50 SOLD Scottydoug
OE shocks. £40 collection only. SOLD
Fuel filler cap, lid and pipe. SOLD
Torsen 4.1 type 2 with fresh oil and seals and powerflex bush inserts. £300 SOLD to Atlex
Wipac H4 head lights and bulbs. £offers. SOLD scottydoug
Flyin' Miata / MTuned coolant reroute kit. £60 SOLD Russell
Reasonably new Fast5 radiator and alloy fan cowl, dual slimline fans. £125 SOLD Wannabe
Fast5 Scuttle mounted washer bottle complete with extended wiring with OE pump plug for plug and play, and a washer pump. £25 SOLD tsp
Unused acrylic door cards. £20 SOLD tep62
TRS 4 point harness, FIA approved valid until 2017, and eye bolts. £50 SOLD Alexey
JDM folding sun visors. £20 SOLD TO ATLEX
Stoney Racing brake booster one way valve and silicone hose. £10 SOLD scottydoug
Nearly new DaveFab jacking bar. £85 SOLD Nurseholliday
Onepaintedman door handles. Upgrade your boring chunky plastic handles for these sexy leather ones. Really lovely. £25 SOLD tep62
Super sexy CarbonMiata carbon fibre LH vented headlight cover. Basically as new, barely used, nice and clean bar one small mark. £75 SOLD scottydoug
Super rare and genuine Volk Group NR-S 15x6.5JJ et35 powder coated satin black, all centre caps present with good RSRs. £350 SOLD tep62
TR Lane GPD. £160 SOLD Tom
Borla cat back, OE mani and decat. £100 SOLD Jersh
1.8 Mini M45 Supercharger Setup, £1050 SOLD
Joyfast medium gear knob. Comes with a woolly hat. £50 SOLD TO ATLEX
Bootlid, front bumper, BBS, BC coilovers SOLD tsp
Already sold:
PPF. On eBay. SOLD
Red bonnet £50 SOLD
