Crumpets
Insert witty remark here...
Post by Crumpets on Jan 6, 2018 21:32:14 GMT
Hi all.
Im in need of a os rear lower arm for my MK1. I've seen contradicting info on any differences between mk1 and mk2.
Can anyone speak from experience in knowing if they are different between mk1 and mk2?
Any help would be fab prior to me doing a wanted post.
Crumpets
Post by Horney on Jan 6, 2018 21:53:26 GMT
I think the mounting points for the ARB drop links are different.
Crumpets
Post by Crumpets on Jan 6, 2018 21:54:59 GMT
I think the mounting points for the ARB drop links are different. That's what I've been told but I've also been told otherwise 😣😣
Rasc
Nutz troll apparently
Post by Rasc on Jan 7, 2018 8:50:14 GMT
Post by FFS Corders on Jan 7, 2018 10:13:56 GMT
Try this link too It says control arms need ball joints swapping to mk1 but otherwise interchangeable link
Crumpets
Post by Crumpets on Jan 7, 2018 12:36:57 GMT
Try this link too It says control arms need ball joints swapping to mk1 but otherwise interchangeable linkCool thanks FFS Corders I did see that thread but it doesn't give much help for the rear imo. Thanks for the help 😊
Rasc
Post by Rasc on Jan 7, 2018 17:41:38 GMT
Try this link too It says control arms need ball joints swapping to mk1 but otherwise interchangeable linkCool thanks FFS Corders I did see that thread but it doesn't give much help for the rear imo. Thanks for the help 😊 No worries however the thread on Nutz is about all suspension, has a definite response to rear situation and also contains the link that FFS Corders posted above. Ohh well..
Crumpets
Post by Crumpets on Jan 7, 2018 22:46:50 GMT
Thank you Rasc.
