Post by bally3 on Jan 30, 2018 16:05:40 GMT
fitted yesterday , harder job than the mk1 especially the rears. anyway heres some before n after shots...... BEFORE.... AFTER.....
Post by bally3 on Jan 30, 2018 16:17:51 GMT
alignment next week...
Post by Horney on Jan 30, 2018 18:18:18 GMT
Nice job. I think they’re easier than the early cars, just different.
Post by bally3 on Jan 30, 2018 18:24:42 GMT
suppose when you done them once , it gets easier........
Post by Horney on Jan 30, 2018 19:21:59 GMT
Pretty much that. Lol.
pewe
Post by pewe on Feb 1, 2018 11:26:53 GMT
If you're DIY'ing and want to corner weight yourself, do as I did on the kitcar and lob a few bags of sand or ballast in the driver's seat to approx. match your weight(assuming it'll be driven more solo than with a passenger)then adjust the ride heights accordingly. That should end up with them as close to optimum setting without extra expense. HTH. Cheers, Pewe.
Post by JamesMk3 on Feb 1, 2018 15:24:40 GMT
If you're DIY'ing and want to corner weight yourself, do as I did on the kitcar and lob a few bags of sand or ballast in the driver's seat to approx. match your weight(assuming it'll be driven more solo than with a passenger)then adjust the ride heights accordingly. That should end up with them as close to optimum setting without extra expense. HTH. Cheers, Pewe. If you are going to do this, and geometry setup (pretty much a necessity after changing shocks/springs), I'd advise letting the suspension settle in before making any final adjustments.
pewe
Post by pewe on Feb 2, 2018 11:09:38 GMT
If you're DIY'ing and want to corner weight yourself, do as I did on the kitcar and lob a few bags of sand or ballast in the driver's seat to approx. match your weight(assuming it'll be driven more solo than with a passenger)then adjust the ride heights accordingly. That should end up with them as close to optimum setting without extra expense. HTH. Cheers, Pewe. If you are going to do this, and geometry setup (pretty much a necessity after changing shocks/springs), I'd advise letting the suspension settle in before making any final adjustments. Totally agree, James. I left mine for about 500 miles before adjusting and for sure they had settled .
Post by bally3 on Feb 4, 2018 13:46:48 GMT
put 70 miles on the suspension today , well impressed , running quite low but not bottoming out at all , only 1 minor scrape going over speed bump in village. normally a fair weather car but today it had a winter blast.
Post by bally3 on Feb 4, 2018 13:47:30 GMT
