Post by Zed. on Jun 7, 2019 22:43:14 GMT
what cams & from where, we need information.... seriously, I'm thinking of getting some cam's ground..... Rich. Rich, these came from Japan at a Huge cost. They started as M2 / Mazdaspeed, then re ground for time attack use. I had to significantly modify the head to make them rotate thought they were'nt reprofiled standard as the lobes looked too thick! also presumed they'd need the head relieving, guess youre going solid followers then? also, whats the lift? (you may need to releve some of the headbolt bosses for high-lift as the follower bores are not machined deeply & they may collide ) I'm thinking about L1 & BD3 profile's but like yours these would need to be ground from a blank (for lobe profile & to keep a sensible base-circle) if you've bored +3mm, any idea as to the bore's wall thickness? all I've read about the 1.6 is that they were a bit 'thin' Rich.
Ry
Post by Ry on Jun 8, 2019 11:59:33 GMT
presumed they'd need the head relieving, guess youre going solid followers then? also, whats the lift? (you may need to releve some of the headbolt bosses for high-lift as the follower bores are not machined deeply & they may collide ) if you've bored +3mm, any idea as to the bore's wall thickness? all I've read about the 1.6 is that they were a bit 'thin' Rich. Yeah, the bosses and follower bores were also massaged! Using China's finest carbide burrs. They are very thin walls, but Toda reassured it was it's safe limit, and even offered 1750cc as one step further Providing everything was balanced etc it should be fine, don't know how it would fair in boosted applications tbh. As will generate a lot more heat
Ry
Post by Ry on Jun 8, 2019 12:14:29 GMT
Post by Vindi (Russell) on Jun 10, 2019 8:16:21 GMT
Nice work, this should really scream!!
Ry
Post by Ry on Jun 13, 2019 19:57:17 GMT
Ry
Post by Ry on Jan 13, 2020 22:30:39 GMT
Engine built. Ready to go in
Ry
Post by Ry on Jan 13, 2020 22:32:23 GMT
Fitted. Coolant pipe mocked up etc. Ford coilpack instead of eunos one too
Ry
Post by Ry on Jan 13, 2020 22:36:15 GMT
Facet works fuel pump and malpassi filter king setup. To upgrade the aging system
Ry
Post by Ry on Jan 13, 2020 22:39:36 GMT
Fuel system installed and started to fix coolant routing Exhaust manifold replaced with a mazdaspeed 4-1 with heatshield
Post by swordspork on Jan 14, 2020 8:36:37 GMT
Very nice. Centre exit exhausts are so cool. Like the old minis.
You wouldn't happen to have the old hks cams floating around would you....?
Ry
Post by Ry on Jan 14, 2020 10:06:21 GMT
Very nice. Centre exit exhausts are so cool. Like the old minis. You wouldn't happen to have the old hks cams floating around would you....? Long gone buddy
Ry
Post by Ry on Jan 14, 2020 20:56:22 GMT
Slightly modified my waterpump
Ry
Post by Ry on Jan 17, 2020 9:24:31 GMT
Converted to a Tailgate McNoIndicate waterpump, plan turned out pretty well. And fitted a 70mm thick Civic radiator instead of the 52mm that I had
