Post by Zed. on Dec 31, 2019 23:21:33 GMT
anyone had any experience of a dropped floor on a mk1 (NA)? I guess mk2's are the same but as I've a mk1 then... I know Russel has / had a modified bodyshell & I believe it had dropped floors but has anyone else any experience with such? I'm able to chop & fabricate the section & welding is no problem Rich.
Post by Vindi (Russell) on Jan 1, 2020 3:06:34 GMT
I've got 2 cars with dropped floors ... my Mk1 has had both sides done and I have a Mk2 rolling shell with the driver side done that will ne for sale shortly
Happy to get you pics of anything I can find ... also, there's a discussion about this on Trackable Miatas over on FB with a few US bods chiming in with pics and measurements
Post by dadbif on Jan 1, 2020 10:04:45 GMT
What do you do, just plate across the bottom of the frame rails?
Post by Zed. on Jan 1, 2020 11:24:52 GMT
I've got 2 cars with dropped floors ... my Mk1 has had both sides done and I have a Mk2 rolling shell with the driver side done that will ne for sale shortly Happy to get you pics of anything I can find ... also, there's a discussion about this on Trackable Miatas over on FB with a few US bods chiming in with pics and measurements Russell you didn't do the surgery yourself then? I've just requested to join Trackable Miatas What do you do, just plate across the bottom of the frame rails? www.miataturbo.net/race-prep-75/floor-drop-kits-101825/some info / links to US kit sellers, personally I'd be making my own as thats sorta what I do.... Rich.
Post by dadbif on Jan 1, 2020 12:27:29 GMT
Why would you need a kit, itโs only a bit of bent plate...
Post by Zed. on Jan 1, 2020 12:35:19 GMT
Why would you need a kit, itโs only a bit of bent plate... read forums & farcebook, most owners buy pre-made as opposed to fabricating / building themselves as to bent plate, well theres the optoin of adding strengthening ribs, swage-lines and skids to the new pan andalso reinforce the dummy chassis section (the so called 'frame rail'?) I sorta diy stuff so already have rough drawings (scribbles) but am open to advice from those with prior experience Rich.
Post by Zed. on Jan 2, 2020 14:38:04 GMT
Post by JamesMk3 on Jan 2, 2020 14:57:16 GMT
...obviously based on LHD cars (USA/Canada)... Just read it in a mirror ๐
Post by Zed. on Jan 2, 2020 17:16:17 GMT
...obviously based on LHD cars (USA/Canada)... Just read it in a mirror ๐ good point the car's floor is different size & shape on either side so any images of 'Drivers' floors will be different Rich.
Post by smighall on Jan 2, 2020 21:52:07 GMT
Defo interested in what you do on this, i've looked into it a bit as that was my plan although now undecided since i made a bag seat instead which seems to get me where i need to be. A bit lower still would probably still be preferable though
