Post by zoona on Apr 5, 2020 9:23:55 GMT
This is the loom to the front left light, and i have a mystery wire. Black and red ending in a push fit connector (just like the horn connector) Any ideas? Alternatively, does anybody have a link to a wiring diagram that is not just schematic? i have the normal one, and that helped me identify the horn wire, because i could go and find the horn relay and identify the colour of the wire. But i need one that will help me find a particular wire from it's location in the car. Does that even exist?
Post by martiny on Apr 5, 2020 9:53:17 GMT
What colours is the wire and is it wrapped to the fan or headlight wires just out of shot? I'll go and take a look for it on mine.
Is it the same plug as the one you labelled Horn? (Is it the other horn?)
Post by zoona on Apr 5, 2020 10:13:28 GMT
Thanks very much.
Black and red wire. I have stripped everything off the loom, so it's not connected to anything - just runs with all the other wires.
Yes, same black plastic connector as the horn.
Ah. Could it be air con compressor? I removed that years ago...
Post by martiny on Apr 5, 2020 10:23:35 GMT
That's possible. I'll have a look.
Post by zoona on Apr 5, 2020 10:27:34 GMT
Post by martiny on Apr 5, 2020 10:44:50 GMT
Yes, that's it: Aircon compressor clutch wire.
I just removed AC from mine recently and remembered there was a little plug tucked away down between the power steering reservoir and the popup motor. Just went out and had a look; same plug, red and black, appears out of the wrapped loom going to the popup motor.
Post by zoona on Apr 5, 2020 14:12:57 GMT
brilliant. thanks for the help.
