Rasc
Nutz troll apparently
Post by Rasc on Aug 5, 2020 14:02:30 GMT
All done and back together.
Went pretty well apart from the sheared anti roll bar bracket stud. Grrrr...
Post by wannabe on Aug 5, 2020 15:09:37 GMT
Well done!
Post by boggissimo on Sept 28, 2020 11:31:04 GMT
I went for the MX5 Parts all in one package but added the front crank seal plus the two cam seals. Which engine is it? 1.6 short nose? 1.6 long nose? 1.8? I've got a bit of a squeak and the belts on mine look tired. I have no idea when they were last changed, so was going to do this job too.
Question is, how do I know what length of 1.6 nose I have?
Post by Zed. on Sept 28, 2020 12:56:13 GMT
Question is, how do I know what length of 1.6 nose I have? 'Shortnose' (early / '89 to ~ mid '91) crank pulley has 4 slots. 'big' nose crank pulley have 8 slots... the 1.8 & later (mk2 onwards??) 1.6's have a diferent pulley for 'multi-vee' belts that is 'plain' without slots and interchangable with the 8 slot items if you also use corresponding alternator & waterpulp pulleys for the improved belt design ALSO.... 1.6 & 1.8 mk1 waterpumps differ as the alternator adjustment strap mounts on a seperate (cylinderblock) mounted bracket on the 1.6 whereas the 1.8 have the strap bolted to a lug on the waterpump. also the 1.6 & 1.8 have diferent cambelt tensioner bolt threading, one in the cylinderblock with a plain / clearance hole in the waterpump and the other uses a shorter bolt that threads into the waterpump only..... ^^ but I cannot remember which Rich.
Post by boggissimo on Sept 28, 2020 14:47:14 GMT
Question is, how do I know what length of 1.6 nose I have? 'Shortnose' (early / '89 to ~ mid '91) crank pulley has 4 slots. 'big' nose crank pulley have 8 slots... ALSO.... 1.6 & 1.8 mk1 waterpumps differ as the alternator adjustment strap mounts on a seperate (cylinderblock) mounted bracket on the 1.6 whereas the 1.8 have the strap bolted to a lug on the waterpump. also the 1.6 & 1.8 have diferent cambelt tensioner bolt threading, one in the cylinderblock with a plain / clearance hole in the waterpump and the other uses a shorter bolt that threads into the waterpump only..... ^^ but I cannot remember which
Heheh OK thanks - mine is a 1.6 so the last couple of points are moot for me anyway. Mine is a 91 but don't know when in 91 so will have a look at the crank pulley :-)
Cheers!
Post by Zed. on Sept 28, 2020 15:11:28 GMT
Heheh OK thanks - mine is a 1.6 so the last couple of points are moot for me anyway. Mine is a 91 but don't know when in 91 so will have a look at the crank pulley :-) the later pump allows using the lighter adjuster-strap but thats less than a burger so not noticed by most whats your vin number decode to age wise? www.japan-partner.com/check-manufacture-year.htmlmy silver Eunos is supposedly November '91 so lnc & rear subframe 'back' brace bar..... Rich.
Post by boggissimo on Sept 28, 2020 18:29:51 GMT
Ah yes, I did that when I first joined on here. 1991 month 9, so September. That could be mid or late so will probably still need to look at the crank pulley!
Post by boggissimo on Sept 30, 2020 8:16:44 GMT
Ah yes, I did that when I first joined on here. 1991 month 9, so September. That could be mid or late so will probably still need to look at the crank pulley! Had a look last night, crank pulley has 8 holes so that makes it a long nose. Also noticed a load of wet-looking (not oily) gunge below the power steering pump, and power steering fluid level is low, so might have a leak somewhere
Post by Zed. on Sept 30, 2020 8:48:06 GMT
Also noticed a load of wet-looking (not oily) gunge below the power steering pump, and power steering fluid level is low, so might have a leak somewhere common issue, they loose pas fluid if driven hard Rich.
Post by boggissimo on Oct 5, 2020 12:06:27 GMT
I found some Slick 50 at a discount in Halfords while getting some other stuff, so topped it up with that. Will check later whether it lost any during a sprint I did yesterday!
Also, to get back on topic, I ordered a timing belt change kit via MX5 Heaven on ebay, and they also sent me a water pump that I didn't order. I had already ordered one somewhere else via ebay so will have a spare for next time :-)
Post by boggissimo on Oct 22, 2020 13:40:15 GMT
Halfway through this job now, and after my initial surprise that there was *another* radiator in the car, I realised it was for the air conditioning. Mine doesn't work, and surely putting the roof down is a better alternative anyway, so I was thinking of getting rid of the AC pump, radiator and other gubbins. Of course now I can't drive the car to get it de-gassed unless I finish the cam belt job, which kind of defeats the point of doing the AC delete while everything else is being done. Of course the AC may not be working because it hasn't got any gas in it anyway...
So, does anyone know how to check the gas level in the AC without it disappearing up into the ozone layer?
Post by Zed. on Oct 22, 2020 17:10:49 GMT
theres a 'schraider' valve in the ac pipework (similar to a tyre valve) that you can 'press' to check for pressure, chances are the system is empty anyway Rich.
Post by boggissimo on Oct 24, 2020 14:52:31 GMT
Had a bit of a wrestle with the water pump and hoses today (I'm replacing all the hoses as I go, with Stoney Racing ones), and discovered that the outlet pipe (metal pipe between radiator bottom and water pump, in between two hoses) is badly corroded. Was surprised to see the only place to get them was MX5Parts at £40 for a new one, so I found a used one from Suffolk Mazda at £13 instead. Seems daft to pay more for the pipe than I paid for the water pump itself!
